16-02-2005, 9:40 AM
#1 (permalink)
Electrical Regs......again!!!!!!
Hi all,
What's the definitive answer....Can I run a cable from a socket up a wall terminated to a double socket to power a wall mounted screen or do I need a sparky to do it for me???
16-02-2005, 3:34 PM
#2 (permalink)
Thanks: Gave 236, Got 148
Basically, from 1 Jan 2005, any competent person can install, BUT,
the job must be inspected and tested by an approved person.
For that particular job, a Minor Works Certificate would be issued.
If your HC work started before 1 Jan 2005, then you can do it yourself.
edit:
Just make sure you use the correct size cables etc. and your existing
power circuit is suitable for this addition.
16-02-2005, 8:36 PM
#3 (permalink)
Thanks: Gave 7, Got 15
If this is not in your kitchen, then you can do this work yourself as it is exempt from the new regs.
16-02-2005, 9:03 PM
#4 (permalink)
Can you explain that statement please Woody.
Johnny
16-02-2005, 9:29 PM
#5 (permalink)
Thats is presuming that the person doing the work is competent enough to check other factors.
16-02-2005, 9:54 PM
#6 (permalink)
Table 1 of Approved Document P states ...
"Work that is not in a kitchen or special location and does not involve a special installation (d) and consists of:
.... Adding socket-outlets and fused spurs to an existing ring or radial circuit ..."
16-02-2005, 11:32 PM
#7 (permalink)
Note (b) of Table 1 states:
"If the circuit's protective measures are unaffected"
Note (e) of Table 1 states:
"Only if the existing circuit protective device is suitable and provides protection for the modified circuit, and other relevant safety provisions are satisfactory".
I would argue that you need to have some professional Knowledge to decide if
these two criteria are met.
Johnny.
17-02-2005, 8:41 AM
#8 (permalink)
Thanks everyone for your help. I'll have to get a copy of the regs. I think I am competent as I am a fully qualified Avionics Engineer (aircraft electronic systems). Nothing to do with a house I know but load calculations and theory should be similar if not the same!!
17-02-2005, 8:46 AM
#9 (permalink)
Ed, the IEE wiring regs are a little bit full on. You will have many hours of fun reading them  . As you say, with your background, you should be ok.
If you are unsure, one extra socket installed by an electrician, will not cost you too much..........
17-02-2005, 9:02 AM
#10 (permalink)
Thanks: Gave 3, Got 0
has any one got a link to regs ?
17-02-2005, 9:24 AM
#11 (permalink)
Thanks: Gave 22, Got 91
As part of the training for my job, I am doing a course that involves some electrical work. It wont get me a full qualification but I am learning quite a bit about regs. As explained by our tutor (a qualified electrician obviously!) you are fine doing things like changing face plates, ceiling roses, spurs from other plugs etc without having to get them inspected. What you cant do (without inspection) is add new circuits e.g. an extension or garage etc, kitchens and bathrooms, modifications to the CSU or other large jobs. What you are planning to do should be fine!
17-02-2005, 9:35 AM
#12 (permalink)
Mitsi, you are fine doing these jobs if you are able to assess other criteria about the existing circuit characteristics and its protection.
This is the stumbling block for a lot of DIY'ers.
Johnny.
17-02-2005, 5:37 PM
#13 (permalink)
Thanks: Gave 2, Got 1
I think it's worth noting that qualifications and experience alone do not make you a competent person I'm afraid. You have to be specifically registered as a "competent person" and that doesn't mean just having professional registration, it is specific to the new codes. I have a HNC in Electronic engineering, a BEng in electronic engineering and am registered as a Chartered Engineer with the Engineering Council via the IEE, yet I am not considered competent!
Having said that, I'm reasonably sure Johnny Thunder is correct that fitting a standard socket outlet is allowed anyway. Besides, if you electrocute yourself or blow the rest of your ccts, who are you gonna sue??
Link HERE to IEE regs about Part P. Would be grateful if someone could confirm the link is OK just in case it's a members only page.
Reason: addition
17-02-2005, 6:30 PM
#14 (permalink)
Thanks: Gave 6, Got 63
No problem with the link Pj.
17-02-2005, 7:24 PM
#15 (permalink)
Thanks Steve, I tend to have a high rate of failure when it comes to forum attachments and links!
