Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 10-02-2005, 6:07 PM   #1 (permalink)
Thanks: Gave 4, Got 16
Daft Question: Re: Surround Sound 5.1 Speakers !
Ok
Here's a stupid question !
I have a Sony DAVSB100 Home Theatre 5.1 Surround kit connected to my tv.
Just a thought re: the front surround speakers that are marked "L" and "R"..
Does this mean that the left speaker for example should be positioned to the television's left - ie if you turn around to face outwards with the screen ... or does it mean to your left as you look at it....
Only, I have my speakers placed left and right as I am looking at it front on and listening to some sound effects, it sounds like they might be the wrong way round !!!!
Can anyone please clarify ??
Sorry again for the silly question, but I would really like to know !!
Paul
Paul Cooksley is offline   Reply With Quote
Old 10-02-2005, 6:13 PM   #2 (permalink)
Jamiroquai78's Avatar
yes its a silly question seriously though I asked dafter ones than that on my thread
Left is as you look out from inside the telly ( dont take the back off and try it just stand behind it to help)
Jamiroquai78 is offline   Reply With Quote
Old 10-02-2005, 6:18 PM   #3 (permalink)
systemsdead's Avatar
Thanks: Gave 103, Got 71
does it make any difference not fought about it before,if that is right mine are the wrong way round lol
systemsdead is offline   Reply With Quote
Old 10-02-2005, 6:19 PM   #4 (permalink)
Cheers mate!
I had a sneaky feeling this was the case when I could hear sound effects going the wrong way with the picture on screen!
Derrrr !!! I am off to lie down in a dark room and take my medication !!!
Cheers!
Paul
Old 13-02-2005, 11:26 PM   #5 (permalink)
LDR
LDR's Avatar
Thanks: Gave 15, Got 11
The Left & Right speakers should be located to the left and right of the screen as you look at them from your seating position, not from behind the screen.
For clarification Click Here
LDR's DVD's
Cinema : ScreenPlay 4805 | Denon AVR-2802 | Pioneer DV656a | Mission m5 (6.1) | Velodyne CHT-10 | SKY+ v2 | Sony CDP-CE345 & MDS-JE520 | Philips Pronto | Scorpion & QED Cables The Lounge : Panasonic TH-50PX70 | Onkyo TXSR606 | Panasonic DMP-BD60 | SKY+ HD | Kef KHT 2005.2
LDR is offline   Reply With Quote
Old 15-02-2005, 10:36 PM   #6 (permalink)
Supersonic's Avatar
Thanks: Gave 27, Got 24
Definitely agree with LDR. It could well be that they are connected and positioned (attached?) incorrectly - and by switching you've got them the wrong way round?
Try the THX optimode audio tests on Star Wars 1 or 2, or a calibration DVD like Avia to check for certain that you're hearing the right sound from the right speaker
Sanyo Z3 pj, Panasonic TH-42PZ80B, Denon 2805 AVR, AE Aegis Evo3B 7.1, Pioneer DV-575A & DV-600AV, Sony RDR-HX510 DVD Recorder, Sony Freeview VTX-D800U, Humax Foxsat-HD Freesat.
HTPC: GA-MA78G-DS3H/Athlon 4850e/ATI 3470 gfx
Supersonic is offline   Reply With Quote
daft, question, sound, speakers, surround
