Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray Review
Léon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray Review
Old 25-09-2004, 10:20 PM   #1 (permalink)
Thanks: Gave 63, Got 39
Can i fix it..?
Ive had a Philips DVDR1000 recorder about 2 years now and its decided to play up. Switched it on the other week and it just showed an error code.Ive had no luck finding out what the code means apart from updating the firmware (which it is updated)
If i run the self test by holding play when i plug the machine in it sometimes (twice infact) runs through and says all is ok. I can then switch the machine off and on and its then fine as long as i dont turn the thing off. Unfortunately someone in my house hold switched it off yesterday and now its doing it again but the self test wont work now either. I know the machine is physicaly ok its just having trouble initializing itself. Ayone with advice or websites that may help would be apreciated.
Id rather try and fix it myself if at all posible before i take it to a repair shop.
Spooksta is offline   Reply With Quote
Old 29-09-2004, 1:04 PM   #2 (permalink)
Thanks: Gave 114, Got 84
Try the DVD Recorders and Media Forum.
http://www.avforums.com/forums/dvd-blu-ray-recorders-recording-media/
You might get more help there.........
Cosmic's attic home cinema project99% Finished) Have a look!!
cosmic023 is offline   Reply With Quote
fix
