20-09-2004, 12:03 PM
#1 (permalink)
| | Guest | Back lighting Plasma Screen
I've just mounted my pdp-504 on my living room wall (a HUGE improvement over the table top stand!).
I've got this idea of back lighting the screen, by putting coloured light tubes either side of the screen between the screen and the wall. I think this could have a very nice effect, perhaps using blue cold cathode tubes?
Has anyone done something similar? Also, where can I get some suitable lights? I looked in Maplins but they only do Cold Cathode tubes that run off either a PC power supply or a 12v car system. Does anyone know of somewhere I can obtain mains-powered Cold cathode tubes?
Cheers,
Mat.
20-09-2004, 12:57 PM
#2 (permalink)
| | Moderator
Join Date: Dec 2002 Location: Our house , in the middle of our street
Thanks: Gave 111, Got 444 |
Quite early on in the "plasmas out thread" there is a set up with back lighting , think its fulabeers iirc , go have a look
__________________ My opinions expressed here do not represent those of the AV Forums or it's associated websites Need a TV Guide ? Look here. |
20-09-2004, 1:33 PM
#3 (permalink)
| | Senior Member
Thanks: Gave 56, Got 54 |
I seem to remember something about backlighting conventional CRT TVs as this is supposed to give a better perceived image quality (over watching in a fully dark room). There is a specific temperature of neon tube (?6500K?) which was meant to give best results. Not sure if the same applies to plasmas though it wouldn't surprise me. I'll have a look when I get home and see if I can dig anything up.
__________________ flickr HC - Rotel RSP-1068 Processor, Mac Mini running Plex, Arcam A90, Totem Arro Speakers TV - Panasonic TH42PHD8 with Lumagen HDP
20-09-2004, 1:50 PM
#4 (permalink)
| | Guest |
After some more research, I'm under the impression that buying a set of Cold Cathodes for a PC case would do the trick if coupled with a 12v power supply available from Halfords....
30-09-2004, 7:37 AM
#5 (permalink)
| | Guest |
I have used a type of LED "rope" light before. Be carefull that what ever you use doesn't cause patterning on the screen.
30-09-2004, 8:24 AM
#6 (permalink)
| | Guest |
What do you mean by patterning?
Surely any light that's behind the screen won't affect it?
Mat
30-09-2004, 6:06 PM
#7 (permalink)
| | Member
Thanks: Gave 0, Got 0 |
I'd ask "Fulabeer" Have a look at his set-up in the thread "Get your plasmas out for the lads - Pt II" His is on the second page - let me know what you think (I know I'm jealous)
01-10-2004, 9:20 AM
#8 (permalink)
| | Guest |
I bought 2 blue cold cathode tubes (the sort that you use in PC case modding!), and I wired them to a suitable mains transformer from Maplins, which works perfectly.
They come with sticky pads and I intend to mount them on the wall either side of the plasma mounting bracket. They need slightly longer wiring, so I need to get down to a spot of soldering this weekend and hopefully I should be able install the lights and post a piccy.
Cheers,
Mat.
29-10-2004, 6:47 PM
#9 (permalink)
| | Guest |
Right, finally got around to getting photos. The lights are not bright enough to really notice with the TV on, but it does look very pretty with the TV off....
Cheers,
Mat
01-11-2004, 12:40 PM
#10 (permalink)
| | Veteran Member
Thanks: Gave 76, Got 211 |
That looks really good. How many tubes did you use and how much did it all come to?
I've suddenly become tempted to backlight my TV and maybe the equipment rack and main speakers...
01-11-2004, 1:04 PM
#11 (permalink)
| | Guest |
it's just 2 cold cathode tubes from maplins, plus a suitable mains transformer. I think I spent about £30 altogether. If you intend to use many tubes I am sure it is probably cheaper to obtain them off the net from PC modding websites.
See my other post here for more info.
Cheers,
Mat.
