Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
My Bloody Valentine - Special Edition Blu-ray ReviewTerminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD Review
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Old 25-07-2004, 12:44 AM   #1 (permalink)
rob j's Avatar
Thanks: Gave 2, Got 4
Thumbs up Started Garage to HC Conversion!
Hi all
After many months of research (mainly done in these forums )Three weeks ago I finally started work on converting my garage into a home theatre.
Initially it was planned to do a set up in our loft space, but that plan came to an end as too much work would have had to have been carried out remove a chimney breast and keep the building structurally sound.
The knowledge of the members of these forums in all aspects has been a huge help – Thanks guys! especially where sound proofing was concerned let alone views on HC equipment
Having had a passion for movies I jumped on the DVD band wagon about three years ago. Not soon after I was wanting the full HC setup, after a curious stroll into a Bose demo outlet and listening to a lifestyle system. Although I didn’t buy any of their products there and then (I was tempted though! ) I went back with the taste as to what could be achieved and surpassed.
So I set about it and here are some pictures to show you how I have got on so far:
The Garage
rob j is offline   Reply With Quote
Old 25-07-2004, 12:58 AM   #2 (permalink)
rob j's Avatar
the dimensions of the garage are 174" X 103" X 94" high
However, behind the stud wall wll be a 2ft wide storage area, so the actual HC will be 150" X 103" X 94" high. The roof slopes slightly forward aswell, about 2" in all!
First thing we did was to construct a frame for the stud wall at the back which will double as the storage shelf/cabinet for all of the equipment
Old 25-07-2004, 1:06 AM   #3 (permalink)
rob j's Avatar
The struts went up - and were filled with 'Wickes Heavy Density Slabs', and were then plasterboarded over
The first ceiling board goes up. We filled the ceiling joists with 150mm Rockwool insulation, from Wickes
The left hand wall nearly finished
Old 25-07-2004, 1:15 AM   #4 (permalink)
rob j's Avatar
The left side wall with speaker cable fitted behind, as well as wiring for the wall up-lighters
Again, the rear wall cabinet/stud wall. This should give a better impression of what the equipment positioning will be like. All equipment will be on this shelf; Receiver, DVD player, projector and freeview box. For added effect, 2 LED downlighters are being placed in the roof of the cabinet to give a nice orange glow
Will post the rest tomorrow!
Thanks!
Old 25-07-2004, 5:27 PM   #5 (permalink)
Assured Advertiser
ReTrO's Avatar
Thanks: Gave 2, Got 25
Looks to be going well.
Have you thought of putting any of your speakers into the walls or ceiling, or enclosures in the walls?
Make sure the false wall is very sturdy or you make get it resonating at low frequencies.
What are you planning on using for lighting control?
P.J - HiFi - Home Cinema - Home Automation
----- The forums longest serving member -----
Assured Advertiser
ReTrO is offline   Reply With Quote
Old 25-07-2004, 6:35 PM   #6 (permalink)
rob j's Avatar
More pics as promised...
The channel for all the electrical wiring - lights and mains.
The front wall again - 'QED Bronze Special Edition' speaker cable running behind plasterboard. Speaker positioned for a 6ft wide screen
The sockets, for the lighting - will control wall lights, ceiling downloads and cabinet downlights
Old 25-07-2004, 7:13 PM   #7 (permalink)
rob j's Avatar
Thanks Retro!
For the speakers, I've got a set of brand new Kef KHT2005.2 eggs and 2010 Sub that are still in their boxes from being bought 2 months ago. Ideal for the space I've got to work with. I had thought about enclosing them in the walls, but then we'd have to bring the plasterboard further in from the brick wall to accomadate them flush-fitted. So they will be screwed to the wall instead.
Incedently the walls of the garage are composed of a layer of breeze-block and a layer of brick, and the floor is concrete.
The frame is very strong and rigid, and will be composed of a layer of plasterboard, two layers of High Density slabs, and a layer of MDF on the garage door side. All will be sealed with slicone.
Also, the garage door seals shut when closed, so heat is conserved, and sound loss will (hopefully) be minimal, especially as in front of this frame will be a bulky 3 seater leather reclining sofa.
I ordered some remote controlled dimmable switched from TLC. We already have one in our house and works fine.
Old 25-07-2004, 7:16 PM   #8 (permalink)
Assured Advertiser
ReTrO's Avatar
Sounds like a good job.
I use a chrome version of the twin dimmer in my bedroom, very good value it is too.
I've popped a link in the speakers forum for ideal speaker placement, might be worth a look.
Assured Advertiser
Old 25-07-2004, 7:23 PM   #9 (permalink)
rob j's Avatar
The rear wall. The far right hand side will be a removable escape hatch.
One of four ceiling downlight, ordered from TLC
Rear wall cabinet, fitted with four double mains sockets, ordered from TLC. Finished yesterday after much trouble!
Cabinet downlights
Old 25-07-2004, 7:39 PM   #10 (permalink)
rob j's Avatar
Rear wall framing sealed yesterday
And that's where I'm upto on the pictures
Today we finished all the electrics and changed over the supply from the old wiring. I Finished painting the remaining bit of wall and painted ceiling the with emulsion, and filled the edges in the cabinet with paintable decorators caulk.
Tomorrow I will get the rear wall filled with the insulation slabs and plasterboard that, and then insulate and board up the area above the cabinet. Will also try and get the rest of the skirting done
Then the room construction will be done. Lovely
EDIT
Funnily enough I had drilled the holes for the speaker cable according to the information I gained from the dolby site! It was extremely useful and has good information on it
Old 25-07-2004, 9:49 PM   #11 (permalink)
Thanks: Gave 1, Got 9
After sitting through some of the DVD's my wife has chosen recently, I think an escape hatch should be added to to the list of requirements for any home cinema
KW1816 is offline   Reply With Quote
Old 26-07-2004, 8:47 PM   #12 (permalink)
LDR
LDR's Avatar
Thanks: Gave 15, Got 11
Ive just tried fitting one of those remote dimmers from TLC, its the 600w load one, and I cant get it to work at all, Ive only got 2 25w bulbs connected at the mo as we are fitting the halogen spots tomorrow, I know the wiring is sound cos we can get the lights to work on/off when connecting the wires together, but nothing when connected to the dimmer switch. Is there a way to test the switch itself to see if its faulty or not ?
LDR's DVD's
Cinema : ScreenPlay 4805 | Denon AVR-2802 | Pioneer DV656a | Mission m5 (6.1) | Velodyne CHT-10 | SKY+ v2 | Sony CDP-CE345 & MDS-JE520 | Philips Pronto | Scorpion & QED Cables The Lounge : Panasonic TH-50PX70 | Onkyo TXSR606 | Panasonic DMP-BD60 | SKY+ HD | Kef KHT 2005.2
LDR is offline   Reply With Quote
Old 26-07-2004, 9:02 PM   #13 (permalink)
Thanks: Gave 111, Got 444
Don't the switches have a minimum load , as well as a maximum one ?
My opinions expressed here do not represent those of the AV Forums or it's associated websites
Need a TV Guide ? Look here.
johnscarlet is offline   Reply With Quote
Old 26-07-2004, 9:06 PM   #14 (permalink)
LDR
LDR's Avatar
Yep, 40w min, and Ive got 50w for now, and nothing..
LDR's DVD's
Old 26-07-2004, 9:13 PM   #15 (permalink)
that was my best effort , sorry.
If its anyuse , B&Q do identical ones , you could pick up another one to check it out , then return it when you get a replacement from TLC.IIRC there were some issues with these switches a while back , the manufacturer were exellent at swapping them out , of course IIDRC they could have been hopeless
conversion, garage, started
