OK, I have a 12'x8' room that I am converting for H/S. I have removed all the plaster on the walls due to most of it being blown.
What would be the best thing to keep the noise from travelling outside of the room?
I am going to replace the floorboards, using insulation between the new boards and the ceiling below. But what should I use on the walls?
Should I just re-plaster it and use something like Auralex on the walls, or go for something else?
Thanks in advance.
Fish
