Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Galaxy Quest Blu-ray ReviewMy Bloody Valentine - Special Edition Blu-ray ReviewThe Universe: Complete Season One Blu-ray ReviewTerminator Salvation Blu-ray Review20th Century Boys: Chapter 2 - The Last Hope Blu-ray Review
North By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray Review
Old 19-06-2004, 3:30 PM   #1 (permalink)
Thanks: Gave 2, Got 0
Help needed with adding phono connectors to VanDamme video coax
I'm looking for help attaching phono connectors to some VanDamme mini video coax.
The cable is buried in the wall and I can't replace it. Unfortunately my DIY skills are hopeless - I've tried soldering some basic phono connectors from Maplins but I really botched it. I tried to use some 75Ohm Canare phono connectors, but they are designed for thicker cables so wouldn't crimp on properly. I really am at my wits end!
Can anyone recommend idiot-proof phono connectors that are suitable for connecting onto quite thin coax cables? Decent quality ones which are recommended for video would be particularly welcome. Alternatively I'd even pay for somebody to come and fit 3 phono connectors if you are experienced at making cables up and could do a good job! Any help would be much appreciated.
Regards
Rob
rob@rar.org.uk is offline   Reply With Quote
Old 20-06-2004, 7:07 AM   #2 (permalink)
rob_w
Posts: n/a
Where abouts in london are you?
Rob
Old 20-06-2004, 8:10 AM   #3 (permalink)
doink
Posts: n/a
Aye, I don't mind giving you a hand if you're close to me (East London)
(If you are having trouble due to the cable being too small for the crimp, you can always add some cable sleeving to give the crimp some purchase)
Old 20-06-2004, 2:03 PM   #4 (permalink)
Brilliant tip, I've now managed to fit the plugs successfully! Thanks to you and to Rob for offers of help.
Regards
Rob
adding, coax, connectors, needed, phono, vandamme, video
