Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
Old 15-01-2004, 11:37 PM   #1 (permalink)
Angry hiding cable on the wall
I am planning to wall mount my speakers, but I cant replaster the wall to hide the cable.
Anybody have any suggestions ?
I also wondered how high I should mount the speakers in a 5.1 configuration ?
briggsy is offline   Reply With Quote
Old 16-01-2004, 6:27 PM   #2 (permalink)
Assured Advertiser
ReTrO's Avatar
Thanks: Gave 2, Got 25
Mini trunking will probably be your best bet them. It can be painted up to wall colour also.
As for heights:
Front 3 at ear level when comfortabley sitting in your viewign position. If that means your centre speaker will be in the middle of your screen/tv, then either go just above or below the screen, but try to keep the speakers all on the same plane.
Rears, about 1-2 feet above ear level when sitting. Just behind the seating position on the sides walls, ideally. Try a few places to see what sounds best to you.
P.J - HiFi - Home Cinema - Home Automation
----- The forums longest serving member -----
Assured Advertiser
ReTrO is online now   Reply With Quote
Old 16-01-2004, 7:30 PM   #3 (permalink)
Thanks,
I'll see what mini trunking is available.
Briggsy
"Enjoy yourself - it's later than you think."
Socrates
Hitachi 500E, Yamaha 640, Denon 2900, KEF 5005, PS2
Old 16-01-2004, 10:45 PM   #4 (permalink)
Thanks: Gave 3, Got 45
i did a pretty good job of this which is simple and effective and easy to remove. If your wall is painted pin the cables flat to the wall and cover with a medium to wide single piece of white masking tape the whole length the cable is attached to the wall.
paint the masking tape twice with the same colour as the wall. It is very effective and is easy to remove if needed
Spacecat is offline   Reply With Quote
Old 17-01-2004, 11:26 AM   #5 (permalink)
Hey Spacecat,
I like it.
Briggsy
Socrates
Old 17-01-2004, 11:11 PM   #6 (permalink)
cheap and worth a go, tell me how you get on
Old 25-01-2004, 8:14 AM   #7 (permalink)
Tesla's Avatar
Thanks: Gave 21, Got 27
I will be doing the same but im going to go up into the loft, through the loft and then down my other wall.
This may sound stupid but do rear speakers go behind you or either side of you?
\\Chris
Tesla is offline   Reply With Quote
Old 25-01-2004, 9:20 AM   #8 (permalink)
Assured Advertiser
ReTrO's Avatar
Conventional surrounds in a 5.1 setup are meant to go on the side walls behind your listening position. Though final placement is all down to personnal taste.
If you are running a 6.1/7.1 system then the rear surround/s go on the back wall.
There are some websites around that show the exact ideal angles to put them at relative to your viewing position, but i'm not sure of the adress for any of them.
Assured Advertiser
Old 25-01-2004, 11:41 AM   #9 (permalink)
fufna
Posts: n/a
Instead of mucking about with masking tape
Why not just use one of the multitude of virtually flat solid core cables around?
These can be painted or if you use a textured paint.. just painted over twice to hide them.
Old 26-01-2004, 11:27 PM   #10 (permalink)
You'd still need to stick the cable to the wall.
How do these flat cables compare to the likes of QED Silver, cable talk etc...
Have you been able to compare ?
Regards
Briggsy
Socrates
Old 27-01-2004, 8:59 PM   #11 (permalink)
fufna
Posts: n/a
Originally posted by briggsy
Regards
Briggsy
Err, sticking the cable to the wall can be done in about 3 seconds.
Some are even self adhesive
As for what they 'sound' like.... they are made of copper.
You would make a more drastic difference to the overall sound of your room by moving a sofa around than you would get from the difference between a solid core flat copper cable and Silver Anniversary.
Old 30-01-2004, 6:20 PM   #12 (permalink)
nuffink wrong wiv masking tape mate, cheap n chearful and if it all goes t*ts up , easy to remove!!!
Old 30-01-2004, 9:55 PM   #13 (permalink)
bobbypunk
Posts: n/a
qed do a flat version of their cables check there site
There is even profile silver a fairly flat silver - biwire version.
Old 31-01-2004, 9:31 AM   #14 (permalink)
fufna
Posts: n/a
Nothing wrong with it apart from the fact that you would have masking tape stuck to your walls!
Old 31-01-2004, 9:33 AM   #15 (permalink)
fufna
Posts: n/a
Here you go
cable, hiding, wall
