Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Old 14-01-2004, 5:54 PM   #1 (permalink)
Taz
Taz's Avatar
Raising floorstanders help req.
Hi all,
I have a pair of B&W 602.5 floorstanders that due to new furniture need raising off the floor 300mm does anyone know the best way to do this please?
My opinions expressed here are not necessarily those of the AV Forums or the associated websites.
Elvish has left the building...
Taz is offline   Reply With Quote
Old 14-01-2004, 7:00 PM   #2 (permalink)
Thanks: Gave 10, Got 16
2 New 300mm high subwoofers?
or maybe just the boxes. Perhaps an X shaped upright (mdf) and a suitible sized top ie make a table / stand. You could then join the assembly to the base of your speakers via screws or Blu-tack (holds very well after a day or so's compression!). Just use a nice thickness of mdf all round and the job's a good un. Wrap a curtain or something similar around the top if you want to hide it.
HTH Steve
banners is offline   Reply With Quote
Old 14-01-2004, 7:04 PM   #3 (permalink)
Assured Advertiser
ReTrO's Avatar
Thanks: Gave 2, Got 25
Hmm....
Lets see, well by deafult it could be a new RTP project.
Need to make summit that will hold the speakers well, same dimesnions as the cabinets. Then you can bolt through from below into the spikes bushes in the bottom of the speakers to hold them firm.
P.J - HiFi - Home Cinema - Home Automation
----- The forums longest serving member -----
Assured Advertiser
ReTrO is offline   Reply With Quote
Old 14-01-2004, 7:20 PM   #4 (permalink)
Ok then, hows about you make subwoofer box of the required dimensions (again thick mdf), use your spikes to locate fixing positions drill and fasten. You now have 1 unit 300mm higher. The box you make wants a hole large enough to fit in a brick then fill the box with bricks to add mass and stability. Spikes could be used under the whole assembly but due to the extra weight may do (more) damage to wooden floors.
HTH Steve
Old 14-01-2004, 7:28 PM   #5 (permalink)
Taz
Taz's Avatar
Some good ideas there guys...I'll fire up the RTP CAD system
Old 14-01-2004, 7:56 PM   #6 (permalink)
Taz
Taz's Avatar
22mm MDF construction...
Old 14-01-2004, 8:02 PM   #7 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 95, Got 1,332
Could get very adventurous and re case the drivers in new taller cases. better finish and sound!
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
hornydragon is offline   Reply With Quote
Old 14-01-2004, 8:02 PM   #8 (permalink)
I s'pose you could part fill the box with sand instead of bricks. You may want to keep the sand in poly bags tho'! unless the 'beach' effect floats your boat
Old 15-01-2004, 11:56 AM   #9 (permalink)
Thanks: Gave 15, Got 35
Hi Taz I'm in the middle of making some platforms like yours, going for 18mm MDF sides and 18mm ply for the tops. spikes on the base and squash balls on the top, something like these :-
http://www.russandrews.com/product.a...OBWFKPFKPVEYCD
slingshot is offline   Reply With Quote
floorstanders, raising, req
