Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
Specific Black AV Stand Requirements Black20VT AV Stands, Cabinets, Seating and Furniture 7 12-11-2009 8:08 AM
SKY dish setup help required leshill Sky and Sky+ 5 07-11-2009 3:59 PM
Amp required to drive Monitor Audio RX8s asifakhtar AV Amplifiers and Receivers 30 04-11-2009 5:42 PM
Guidance on best avr/speakers and cable please Culthero AV Amplifiers and Receivers 4 04-11-2009 2:30 PM
Old 04-11-2009, 8:00 PM   #1 (permalink)
Thanks: Gave 1, Got 1
Guidance Required Please
Ive just bought a house and have been rewiring it this week, I decided to stick in some CAT5 cabling in (two to each TV and 4 to where my future Av gear will be). Ive also put in two Coax's in to each Tv aswell. This is all the run back to one area, is there anything else I may need to install whilst I am at it?
Also what sort of cabling to projectors?
Any other input appreciated!
1stfocus is offline   Reply With Quote
Old 04-11-2009, 9:02 PM   #2 (permalink)
Re: Guidance Required Please
Just another little one. for being the TV I have just ordered 1 hdmi, 1 hdmi to dvi, 1 optical aswell as the two CAT5's that will be there. Anything else I may require.
Old 06-11-2009, 5:22 PM   #3 (permalink)
Anybody?
Old 06-11-2009, 9:58 PM   #4 (permalink)
Thanks: Gave 5, Got 4
Hi again over here!
It might be worth laying a few more CAT5 (or make it CAT6?) runs. My living room AV needs 8. Also I put in 2 for the other rooms and now find for at least one room 4 would have been better. Two is fine for the other rooms, even where I am using one for the phone.
While you are cabling you could be thinking any of the following as it is probably better to take care of them at this stage:
- speaker cable runs
- lighting, loads of possibilities there - for example LEDs
- multiroom control cabling - for example for infrared
Hope this gives you some ideas
newbie1 is offline   Reply With Quote
Old 07-11-2009, 1:31 PM   #5 (permalink)
Thanks: Gave 18, Got 4
Originally Posted by 1stfocus View Post
Anybody?
What did you decide on re the wiring? I would suggest as many Cat5 as you can get. My Media PC, TV, Blu Ray & Freesat all have CAT5 connected to my Router, there's 4 gone straight away!
illingworth22 is offline   Reply With Quote
Old 07-11-2009, 5:45 PM   #6 (permalink)
Bedrooms have two CAT 5 and Two coax at each TV. Living room has two CAT5 at TV then 4 where the AV cupboard will be, plu two coax at tv and Two at Av cabinet, Also wired for Speakers in the loung. May Put Two speaker cables in Kitchen for future multi-room audio. There are other various Cat 5's around house too, for wired internet/phones. Im just gonna put them all in the patch panel then try to figure out the workings of it after!
guidance, required
