As the title suggests. I'm closing in now and almost have all the equipment in terms of AV that I want and its time to start thinking about chasing the cables into the walls.
I wondered what people are using?
1. Are you going straight in with cable then filling over the top?
2. Are you using trunking to house the cables to allow for free movement
3. Is there any niche trunking designed for this.
I need to chase in 3 x speaker cables. 1 x HDMI. 1xPower from TV, 1 Wii Sensor bar cable.
This is an older picture and have some Monitor Audio R225s for left and rights(Wall mounted) and will have a Monitor Audio R250 (Wall Mounted) as a centre, but you can see what I'm trying to achieve or do you suggest a Floating wall Enclosure.
Any help would be greatly appreciated.
