Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray Review
Léon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray Review
Recommended Laserdisc player to output purist signal? LD_OUT Video Scalers, Video Processing and Progressive Scan 55 Today 3:34 PM
Upgrade recommendations from "All in one" System to AV receiver stezie AV Amplifiers and Receivers 11 05-11-2009 3:52 AM
ONKYO TX - SR805 7.1 AV Amp/Receiver problum not geting any video throw amp at all UserNameinValid Onkyo Owners' Forum 42 03-11-2009 6:18 PM
Anyone know much about property share ownership/homebuy? snowkit General Chat 8 03-11-2009 1:57 AM
Old 03-11-2009, 6:19 AM   #1 (permalink)
share av signal to 3 rooms
Hi guys. heres my problem/question.
Im building a new house and i have been looking at putting my Wii in the middle of the house and have the cables run to 3 rooms from there. the controls use bluetooth which seems to work at a fair distance, also the "sensor bars" only send info, not recieve, so i can buy the wireless ones and not have a problem with that.
the problem is i dont know how to split the signal. thinking im smarter than i actually am, i went and bought a roll of RG6 cable, 4 AV wall plates and 3 4-way antenna spliters. i thought the splitters would work fine, but when i tried them, they only work on the power pass output and it is a terrible picture.
Anyone got any ideas on how to split the signals?
Thanks heaps
Matt
fred_wetham is offline   Reply With Quote
Old 03-11-2009, 2:48 PM   #2 (permalink)
Thanks: Gave 5, Got 20
Re: share av signal to 3 rooms
Which output are you using to output from the wii?
Composite or component?
LG 37LC55 LCD / Samsung HT-TZ225 HTK + Wireless Rear Module / Sony PS3 100GB Fatty + PlayTV Module / Xbox360 Elite / Xbox Original 1.6 Revision Running XBMC / Gigabit Ethernet / PC in study Serving multimedia to Laptops & Consoles / 2 Kids & the Missus.
RowdenCO is offline   Reply With Quote
Old 03-11-2009, 2:56 PM   #3 (permalink)
The standard connection from the wii is composite (REd, White & Yellow Phono). You can pick up a switch, which will switch the singnal and allow you to use it on as many machines at the switch allows. The one of the link allows 4. You'd then need to run composite Phono cables to the rooms where the TV's are. This way would allow you to use the wii on one tv at a time, but not on all four.
4 Way Audio Video AV RCA Switch Splitter with Remote Control & AV Cable, Clear Blue
Old 04-11-2009, 2:43 AM   #4 (permalink)
i was going to just use the compisite. i did already think of the switch, but i would rather have it on all 3 at the same time.
Old 05-11-2009, 11:00 AM   #5 (permalink)
Sanders79's Avatar
Thanks: Gave 65, Got 28
Are you still at a stage where you can install different cables? And will you be using an amp have a HDMI output? It might be possible to run the wii through the amp to convert the component signal (if you get the wii component cable) to HDMI and then run the HDMI over cat 5/6 with the appropriate baluns. Just some suggestions and could all be pie in the sky if your setup isn't like this.
Yamaha RXV-1900 with YDS12 iPod dock, MA Radius R90 speaker package with RSW12 sub, Pioneer BDP-320, Sony KDL-40V2000, Sony RDR-HXD970, Sky+, Wii, Harmony 1000, various cables from Mark Grant, Ixos, QED and Van Damme.
Sanders79 is offline   Reply With Quote
Old 05-11-2009, 12:22 PM   #6 (permalink)
You not planning on playing from 3 seperate rooms at a time are you?
rca, rooms, share, signal, wii
