Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Keep losing internet connection since installing Win7 Home Premium G@zz@ Windows 7 9 28-10-2009 4:42 PM
sky installers thatguy Sky and Sky+ 5 27-10-2009 7:41 PM
Help required with installing a second cable AES-SPAIN Freesat 3 27-10-2009 3:16 PM
How to install new HD and keep old programes Sparky83 Hard Drives and Memory - RAM/Cards and Sticks 1 27-10-2009 2:28 PM
Computer Won't Do Autorun of Windows 7 Instal fleetingmind Windows 7 1 27-10-2009 9:40 AM
Old 27-10-2009, 3:49 PM   #1 (permalink)
Thanks: Gave 1, Got 0
New install (cabling advice)
We are renovating the new flat so now is a perfect time to make sure I have the correct cables/points in each room.
Could anyone please advise if what I am planning sounds right or if you could make any suggestions/recomendations.
Lounge (Main AV room)
3 x cat5e points
1 x aerial for freeview
2 x sat for sky plus
I am also having a 5.1 speaker system installed, would it be recomended to have all the cables going into a 5.1 faceplate and then to the amp or not?
Master and 2nd bedroom
2 x cat5e points
1 x sat for Freesat
Would I be able to split the aerial and sat cable to dual feed a twin input recorder or would I need to have 2 of each?
If I wanted to have Sky magic eye setup in this room, what cable would I need to have in both the master bedroom and the lounge?
Thanks you for any advice.
Mike
miked1900 is offline   Reply With Quote
Old 28-10-2009, 12:39 PM   #2 (permalink)
Thanks: Gave 8, Got 4
Re: New install (cabling advice)
Welcome to the forum.
It sounds like the connections you plan on running to each room are adequate, as long as there isn't major upgrading in the future.
The 5.1 faceplate (I assume for speaker connections) can make the cables a little tidier, but you may want to think about a 7.1 faceplate in case you choose to upgrade in the future to take advantage of the new sound formats on blu-ray.
I don't know much (anything) about sky connection, but the freeview aerial can be split almost as much as you like. Beware though that this can introduce a poor signal if cheap splitters are used. You may be better off using a powered distributer, often located in the loft.
Look forward to hearing about the home improvements.
- Word, Riggs
- Word, Rog
gareth_alien is offline   Reply With Quote
Old 28-10-2009, 1:07 PM   #3 (permalink)
Thanks: Gave 61, Got 18
hi,
on the advice of other forum members, I installed 4xcat 5 and 2x sat grade co ax into each room, returning to a media cupboard.
if you're thinking of using sky+ and dab etc , then it would be good to run 5 x sat grade co ax from the loft to your cupboard too.
think carefully about the location of the points in each room, so that they are positioned where you want your TV to be.
also - if you're planning on multi room system that takes wall controllers, you'll also need to plan accordingly.
good luck with it all
House Renovation
Andyjc is offline   Reply With Quote
advice, cabling, install
