Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Cat Problem Earthworm Jim General Chat 8 24-10-2009 11:19 AM
Windows 7 clean install problem - help! frankmcg Windows 7 6 23-10-2009 7:33 AM
Acer 7220g laptop (problem) mazkev Laptops and Mini PCs 4 22-10-2009 4:42 PM
Amp to overcome lip sync problems? jspoi AV Amplifiers and Receivers 17 22-10-2009 4:06 PM
Old 22-10-2009, 4:39 PM   #1 (permalink)
Home Theater Problem - Genius Needed
Hey Folks,
I'm hoping to garner some of the great ideas on the forums here and try to solve my own theater problem. So far I've only got half-solutions and I'd love to hear your thoughts on what else might work;
Best to start with the image and then read on.
I have a beautiful HD projector, 5.1 sound and rolling with XBMC on a laptop as my HTPC which plays all my media over an ethernet link. It all works great except that It's not ceiling mounted...
I have two problems;
  1. I need to find a lightweight box that will hold both the projector and the laptop, probably one with a slope (for the projector). The idea is to attach the 'box' to the ceiling, beside the celing mounted power and ethernet points
  2. Even if I do manage to find and anchor a 'box' to the ceiling I now need to get my 5.1 digital sound signal to the amp. I've had a look for wireless broadcasting units but they all seem ridiculously expensive
Is there a much simpler way to accomplish what I'm trying to do? If so please set me on the right track
Many thanks
/Ry
ryshandyr is offline   Reply With Quote
Old 22-10-2009, 5:12 PM   #2 (permalink)
Re: Home Theater Problem - Genius Needed
Hi Ry,
This is my very first post, so please bear with me as I write.
Where is the CAT5 cable going to from the projector?
Regards
Nigel
mediasolutions is offline   Reply With Quote
Old 22-10-2009, 6:24 PM   #3 (permalink)
Thanks: Gave 5, Got 4
Hi Ryshandyr
I have a similar setup but works as follows:
Laptop connects to AVR (Denon 2808) via HDMI for picture and optical for sound, AVR then sends picture to projector via HDMI cable (15m).
This means I can use a conventional ceiling mount for the projector.
Is there a reason why this would not work for you?
newbie1 is offline   Reply With Quote
Old 22-10-2009, 6:31 PM   #4 (permalink)
Thanks: Gave 2, Got 1
ah, looks like your stuck with some cables showing, unless the ethernet cable is loose, in which case you can attach string to the end of it, and pull it through, then attach the audio cable also to the string, and pull it back through,
lite is offline   Reply With Quote
Old 23-10-2009, 8:39 PM   #5 (permalink)
Originally Posted by mediasolutions View Post
Hi Ry,
Regards
Nigel
The CAT5 port in the roof was intended for the laptop that would also sit up with the projector
Old 23-10-2009, 8:41 PM   #6 (permalink)
Originally Posted by newbie1 View Post
Hi Ryshandyr
Several inches of carpet and floorboards are my obstacles. Did you run the cable in the ceiling or externally along the ceiling?
Old 24-10-2009, 10:22 AM   #7 (permalink)
Hi Ryshandyr
My construction is concrete so I put a tube inside the concrete for this purpose when it was built.
As lite said depending on where and how the cat5 cable is routed you could follow that for either a new sound cable. Or you do the same to put in an HDMI / component / S-video cable to feed the projector from an AVR in a more conventional setup with the laptop feeding the AVR.
In other properties I always found it was possible to feed cables under floor boards, between cavity walls, etc but not always easy! How did you get the cat5 and power socket in the ceiling?
Old 24-10-2009, 3:57 PM   #8 (permalink)
calibos's Avatar
Thanks: Gave 8, Got 17
But if you put cables specifically in the roof at the projector location, why on earth did you put CAT 5 up there for a laptop....beside the projector...hanging from the roof....when instead you could have run a HDMI to the PJ location and had the laptop on a coffee table beside you.
Unless I am misunderstanding something.
Is that the only ethernet cable for the whole room?? Did you run no other cables to the PJ location except power and Cat 5 ???
Sounds like the most wacky unconventional layout I have ever heard of.
Keith D.
calibos is offline   Reply With Quote
Old 24-10-2009, 5:38 PM   #9 (permalink)
Hi Ryshandyr
Before we moved into the house we had the chance to make some minor changes; a socket and an ethernet port in the ceiling were what I thought would be enough.
I'd forgotten about the audio though!
doh!
Old 24-10-2009, 5:42 PM   #10 (permalink)
I had originally intended to do the sound over the air back to the AMP - so all I needed was a video feed (local htpc laptop displaying content on the network).
Since then though getting 5.1 audio across the air is proving to be a complete nightmare.
Hence my need for genius - or loads and loads of cash
/Ry
Old 24-10-2009, 7:20 PM   #11 (permalink)
Ry OK
Here is another idea - use the cat 5 cable to transmit the picture from the AVR to the PJ instead of an HDMI. This means the rest of your setup can be conventional.
I have never done this but it is possible, try another thread on it or google "video over cat5" and you will find products that don't look too expensive.
I think this will solve your problem and avoids any new cables.
Old 25-10-2009, 8:37 PM   #12 (permalink)
Ry OK
I have recently been looking into this - unfortunately all the decent high-res signals require two cat5 cables to carry the signal.
I reckon the carpet and floorboards are coming up
/Ry
Thanks for all the suggestions so far folks - much appreciated.
Old 26-10-2009, 11:20 PM   #13 (permalink)
Hi Ry
Looks like only one cat5 is needed if you only need the video and you can pick them up for a few quid:
HDMI Cat5e - Cat6 Extender - HDMI Over Cat5e / Cat6 1080p 30m Only £32.29 at TVCables
Old 27-10-2009, 12:44 PM   #14 (permalink)
Hi Ry,
Simple solution:
1. Purchase a secure and quality projector mount from Omnimoun - PMD0.5 or so to mount the projector on the ceiling. This will also support cable management and provide adequate cooling for the unit.
2. Purchase a single cable CAT5 HDMI extender from SCP / Habitech in the UK... Audio & Video Cables : Accessories : Structured Cable Products
3. Position the Laptop beside the AVR and connect the audio...
or
Follow step 1 above
Instead of using your laptop for playback, why not use a Network Media Tank like Popcorn Hour or ZyXEL... they are both awesome and not that expensive...
One tip tho, if you think you need just one CAT5 always put a second cable in...
Hope this helps...
Nigel
Old 01-11-2009, 8:31 PM   #15 (permalink)
Hi Ry,
Simple solution:
or
Follow step 1 above
Hope this helps...
Nigel
Great idea - thanks for the links too.
/Ry
genius, home, needed, problem, theater
