Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Wanted : Xbox 360 HDMI only console + power needed Jazz Monkey Jr Xbox 360 Classified Adverts 19 04-11-2009 6:48 PM
Computer powers on without pressing power button WackyZ Motherboards, CPUs, Cases and PSUs 5 25-10-2009 12:10 AM
Class D power amps Rotel vs Bel Canto CLIVEEDWARDS Audio Processors and Power Amps 19 24-10-2009 12:12 PM
How Much Power Does A Plasma TV Use? hybridtheory Plasma Televisions 14 22-10-2009 5:42 PM
Old 21-10-2009, 1:03 PM   #1 (permalink)
royaltiger's Avatar
Thanks: Gave 3, Got 10
Stuck on power supply
Hi all
I am just in the process of building a false chimey breast, "pictures will follow soon" but was stuck on how people power their hifi when its hidden away, basically what I am stuck on is all my hifi will be built into the chimney so it was more a question of how do you turn anything off from the mains, I will have 7 items plugged in but wanted to know how people cut their supply if there was a problem or even just to reboot the cable media box, I suppose I want each plug individually, at the moment I have taken a spur of off a double plug and stuck on ideas of how to connect it all, before it was all chucked into an extension lead with six sockets but do not want that when its out of sight, so would appretiate any ideas or other posts that point the right way
Pioneer SC-LX90 SUSANO Pioneer KRP-500A (isf calibrated) Pioneer BDP-LX91 VirginMedia V+ CableTV B&W804s Front Speakers B&W804s Rear Speakers B&W HTM3s Centre Speaker REL B3 Sub Bass
royaltiger is offline   Reply With Quote
Old 21-10-2009, 2:29 PM   #2 (permalink)
Thanks: Gave 2, Got 0
Re: Stuck on power supply
One idea I have for a similar situation is to fit a switched 13amp spur from my double-socket, and then use a multi-way adapter from a single socket. I am then going to use Bye Bye Standby to remotely switch it all on/off.
Bye Bye Standby do a starter kit with a remote and 3 adapters for £25 if you search around. I've just bought two!
l9nux is offline   Reply With Quote
Old 22-10-2009, 6:18 PM   #3 (permalink)
royaltiger's Avatar
Looks like I will go with 4 single switched units controlling 4 double sockets, at least I can narrow down the situation of a reboot on the cable media box, thanks for all your help out there
Old 22-10-2009, 6:47 PM   #4 (permalink)
Thanks: Gave 5, Got 6
Hi Royaltiger
I also went the "standby killer" route - one touch of the remote and everything powers up.....
Hope this helps
newbie1 is offline   Reply With Quote
power, stuck, supply
