10-10-2009, 5:54 PM
#1 (permalink)
| | Member
Thanks: Gave 16, Got 14 | AndyST's Semi-Dedicated Build Thread
After much research and planning I've now arrived at the build phase of my new project
The aim is to improve my setup to provide the best possible sound from my current equipment, mainly in the areas of positioning and acoustic treatment.
It's not going to be done anytime soon, this is very much a long term project. Comments & suggestions welcome along the way! Master 'To Do' List
I'll keep adding to and updating this as I go along. It's a handy way for me to see where I am with the project and just how much work I have left to do
Designs: - Front Columns - Complete!
- Rear Columns - Complete!
- Column Covering Panels - Complete!
- Bass Traps - Complete!
- Diffusers - Complete!
- Front Wall Layout - Complete!
- Rear Wall Layout - Complete!
- Window Panels - Complete!
- Ceiling
- Lighting - In Progress
Construction
Columns: - Front Right - Complete!
- Center - Complete!
- Front Left - Complete!
- Rear Right
- Rear Left
Column Covering Panels: - Front Right - Complete!
- Center - In Progress
- Front Left - In Progress
- Rear Right
- Rear Left
Bass Traps: - Front Right Column - In Progress
- Center Column - In Progress
- Front Left Column - Complete!
- Rear Right Column
- Front Wall
- Right Wall
- Rear Wall
Diffusers: - Front Wall (6 - Prime 13)
- Rear Wall (5 - Prime 17)
Window: - Acoustic / Light Control Panels (6)
Misc: - Lighting
- Trunking / Cable Management
Software / Calculators Used Latest Update
| Pioneer KRP-500M | Sony BDP-S350 | Sony STR-DA3400ES | 3x Audiolab 8000M | Monitor Audio BR2 | BRFX | BRLCR | BK Monolith - DF | My DIY Build Thread
11-10-2009, 7:11 PM
#2 (permalink)
| | Member
Thanks: Gave 16, Got 14 | Re: AndyST's Semi-Dedicated Build Thread
First column frame is 80% done, just a few more cross beams to add in. Was a lot more work than I expected, I should really invest in some power tools. Hopefully the next one will go a bit faster
Here's my preliminary designs for the front wall. The custom equipment racks will be going in those 2 alcove areas, but I'm still working on the exact designs for them.
11-10-2009, 8:05 PM
#3 (permalink)
| | Member
Thanks: Gave 158, Got 178 | Re: AndyST's Semi-Dedicated Build Thread
I really like the look of your design Andy! Do your self a favour and at least get an power screw driver! I'm sure that now you've built one colum the other two will go up quicker.
A suggestion I would offer to you though would be not to use racks in the alcoves and site your other equipment out of site. I think it would spoil the look of your design and all those illuminated buttons drive me to distraction.
Keep us up to date with plenty of photos mate!
__________________ Optoma HD800X / 84" Screen / Sony Bravia KLV-V40A / Sony HT-IS100 / SkyHD / Harmony One / PS3 / Xbox 360 / Wii / Vaio FZ21E Samsung LE37A656A Black Rose (bedroom) TV. |
16-10-2009, 4:01 PM
#4 (permalink)
| | Member
The first column is complete and in position:
Pretty pleased it all went together without any problems, the benefits of thorough planning I guess
Picked up the materials for the 2nd one this morning so I'll be ready to start work on that tomorrow.
17-10-2009, 6:39 PM
#5 (permalink)
| | Member
Almost done with my design of the power amp rack. Space for the 3 8000Ms I have at the moment with room for 2 more. Intending for that to be part of my next upgrade path, so every channel will have it's own monobloc.
There's a gap at the bottom to draw in cold air and through each shelf in line with the 8000M's heat vents. So there will be no risk of any heat building up and it should have quite a nice airflow.
Similar to the columns I'm planning to attach panels to the frame and also have a hinged door at the front so everything inside can be hidden out of view. More on this once I've finished the designs.
Hopefully they will integrate well into the design of the front wall. There really isn't anywhere else they can go in the room.
| Pioneer KRP-500M | Sony BDP-S350 | Sony STR-DA3400ES | 3x Audiolab 8000M | Monitor Audio BR2 | BRFX | BRLCR | BK Monolith - DF | My DIY Build Thread |
18-10-2009, 7:18 PM
#6 (permalink)
| | Member
Center column is almost done, should be able to get the last few pieces sorted tomorrow night. I tried a slightly different approach putting this one together. Instead of attaching the brackets to the cross beams first I measured out the main supporting beams and attached them where they needed to go on there. This way went a lot smoother as I didn't need to line up all the cross beams during the final phases of construction, they just slotted into place.
Picked up the materials for column 3 as well
19-10-2009, 9:20 PM
#7 (permalink)
| | Member
Center column complete and in position.
20-10-2009, 2:49 PM
#8 (permalink)
| | Member
Thanks: Gave 5, Got 20 | Re: AndyST's Semi-Dedicated Build Thread
looking good, keep the updates coming
LG 37LC55 LCD / Samsung HT-TZ225 HTK + Wireless Rear Module / Sony PS3 100GB Fatty + PlayTV Module / Xbox360 Elite / Xbox Original 1.6 Revision Running XBMC / Gigabit Ethernet / PC in study Serving multimedia to Laptops & Consoles / 2 Kids & the Missus.
24-10-2009, 11:02 AM
#9 (permalink)
| | Member
Decided I need a break from column building this weekend. Instead I'm going to build the covering panels for the front right column, to see if it all goes together like I expect it to.
Here's the acoustically transparent cloth from Maplin (20m), and the wood for the frames.
24-10-2009, 11:24 AM
#10 (permalink)
| | Member
now I see the cloth, I understand what your doing, should be cool. The columns are they being left as untreated wood?
24-10-2009, 11:43 AM
#11 (permalink)
| | Prominent Member
Join Date: Apr 2006 Location: You'd get your feet wet getting here
Thanks: Gave 198, Got 459 | Re: AndyST's Semi-Dedicated Build Thread
will be interested to see how the columns turn out, i've been thinking of adding some to my cinema room for a while
good job so far
__________________ My Home Cinema Room My Gear: 108" Carada Screen, Panasonic AX100, Denon AVR3808, 7.1 B&W 6 Series speakers, Panny BD35(now Region free for Blu-ray!!), HTPC, XBOX 360, WII |
24-10-2009, 12:06 PM
#12 (permalink)
| | Member
Thanks: Gave 16, Got 14 | Re: AndyST's Semi-Dedicated Build Thread Quote:
Originally Posted by RowdenCO now I see the cloth, I understand what your doing, should be cool. The columns are they being left as untreated wood? | That's the plan. Adding wood treatment to them would fill the room with VOCs for some time, and they really aren't nice things to be breathing in.
24-10-2009, 12:07 PM
#13 (permalink)
| | Veteran Member
Join Date: May 2007 Location: The Black Hole formally known as The Abyss!!
Thanks: Gave 603, Got 516 | Re: AndyST's Semi-Dedicated Build Thread
Hi Andy
its starting to come together mate
there`s a lot of bloody screws their though  I bet yer arms dropping off
keep up with the pics... cheers Al |
24-10-2009, 4:59 PM
#14 (permalink)
| | Member
24-10-2009, 6:30 PM
#15 (permalink)
| | Veteran Member
Andy
they really do look great |
