Wadding you can get from CPC also, or if you can find it get some Dacron, kinda hi-tech wadding.
Gaskets are basically to stop your air from leaking from around the driver and amp, or other (deliberate) holes in the enclosure. We at RTP (
) tend to use strips of neoprene foam or similar, so long as it seals well it's good.
