OK chaps... took a couple of pics prior to the second coat
(I actually like the way it looks now so might try to avoid this)
First one is without a flash (this more how it looks in the room)
http://makeashorterlink.com/?C689231E6
Second one is with a flash to give an idea of the texture (beware the flash makes it look very washed out!)
http://makeashorterlink.com/?B279611E6
The finish looks very much like suede, and is IMO easy to achieve
I think it would probably be a bit too much if used on all surfaces in a room (ie ceiling) I have used it on the screen wall and both sides.
I'm hoping it will look even better when the fabric covered acoustic panels go in.
The paint is called "Chocolate Suede" and is made by Crown if anyone is interested.
