3.5 million visitors each month
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Last King of Scotland, The Blu-ray ReviewAfrican Queen, The Blu-ray ReviewCirque du Freak: The Vampire's Assistant Blu-ray ReviewToy Story Blu-ray ReviewClash Of The Titans Blu-ray Review
Vengeance Blu-ray ReviewHellboy Animated: Sword Of Storms/Blood and Iron Blu-ray ReviewThe Andromeda Strain - Motion Picture Soundtrack CD ReviewMulan Blu-ray ReviewJulie & Julia Blu-ray Review
Thread Thread Starter Forum Replies Last Post
New Flat: Lounge design in progress.... richiec77 Home Cinema DIY 89 31-12-2009 11:44 AM
Old 19-08-2009, 6:15 PM   #1 (permalink)
Thanks: Gave 10, Got 9
Help me design my walls!
Guys,
I'm building a shed/home cinema gaming room in my garden. I'm trying to decide on the wall construction method, either to go for double skin with blocks or single skin timber. Obviously blocks is going to be better, but it takes up a lot more room, costs more and takes a lot longer to build.
Here are my rough sketches of what I'm thinking of doing:-
Anyone got any thoughts? If I do the second option I'll do a false ceiling as well. The room is going to be 3mx5m and will have a gym at one end with a plasma etc at the other. I haven't included damp proofing in the first picture, which will be permeable sheeting on the outside under the cladding or ply.
mike.hutch is offline   Reply With Quote
Old 19-08-2009, 6:29 PM   #2 (permalink)
Thanks: Gave 639, Got 544
Re: Help me design my walls!
A room that size a decent builder will have the blocks walls up in a day no bother at about 150 quid inc labourer.
Thats the way I`d go without doubt
albriscoe is offline   Reply With Quote
Old 19-08-2009, 6:33 PM   #3 (permalink)
I think thats going to be the way to go, I'm doing all the building work myself, so it may take a bit longer than a day! It's actually a bit more complicated as well as I'm digging down 500mm to keep the overall height down.
How well do think each one would do at soundproofing?
Old 19-08-2009, 9:43 PM   #4 (permalink)
Thanks: Gave 24, Got 48
look at the gypsum whitebook for the soundproofing info
kit list; samsung m87, ps3, xbox360, wii, onkyo 605, skyhd 160gb macbook, ae speakers(that really need upgrading), Sony hs50 projector, 8ft electric screen
http://www.avforums.com/forums/home-...73-i-made.html
deansocial is offline   Reply With Quote
design, false wall, walls
Copyright © 2000-2010 M2N E. & O. E.
