Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 02-12-2003, 10:44 PM   #1 (permalink)
quick question regarding sending sky signal to another room
I already have the rf2 out feeding a tv in the bedroom, can I use the rf1 out to feed another tv in the house using the Ilink thing or will that not work, I have tried a video sender (from lidl) and not having much luck, although to be honest I've just got in from work and I havent read the manual properly, Just bought a new lcd tv and I'm so inpatient to set it up..
thanks
stolt is offline   Reply With Quote
Old 02-12-2003, 11:29 PM   #2 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 95, Got 1,332
signal will work but no remote control try the sender again
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
hornydragon is offline   Reply With Quote
Old 04-12-2003, 12:20 PM   #3 (permalink)
managed to get the video sender to work, very impressed with the quality to be honest, first time I've used one of these and would recomend them.
question, quick, room, sending, signal, sky
