Originally Posted by TheIcon Not a bad idea at all. Would the full plateform need to be filled or just the front wall facing the speakers? |
Sand is cheap so depends on the strength of the supporting floor how much weight you can add. If it is concrete then I'd fill in the whole space as any gap is going to affect acoustics, especially bass at floor level as likely to be in the direct path of the subs. If you have a timber floor then you could go with a heavy foam block core and fill underneath, around and above it with sand.
