Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
Room Acoustics Examined - Part Two Phil Hinton AVForums Video Productions 10 06-09-2009 2:11 AM
My Little Portuguese Project LiPePT Members' Home Cinema Gallery 36 11-08-2009 3:53 PM
How to project over super long distances megaboots Projectors 2 11-08-2009 6:28 AM
Old 11-08-2009, 7:46 AM   #1 (permalink)
Thanks: Gave 5, Got 11
First attempt - My back room project
Hi all
I've been lurking around the forum for a while now checking out others great setups, so I thought I would finally start my little project. I bought my first house about a year ago now and with the gf going to back to uni I got permission to convert the rear room to a cinema/gaming/office. It used to be a garage but the previous owner converted it for an extra bedroom and utility room.
Now its not the biggest room (2.8m x 2.2m) but I hoping to make the most of it by hiding in there when her shows are on and locking her in when she has work to do........ then playing on my main kit in the lounge!
Here’s what I plan to do, but not sure where to put things yet.
1. Remove the back door (ive never used it) and put a large window in (ordered).
2. Rip the floors up and put laminate flooring in.
3. Put my spare Sony 32" on one of the walls.
4. Remove and put plugs in where needed.
5. Put AV kit in (surround, xbox etc)
6. Add some kind of heating.
7. Put a desk in.
8. Decorate etc.
Now for couple of pictures, cleared the room out and filled in a few holes. I couldn’t seem to take a pic that didn’t make the room look really tiny…
And here’s what I’ve done in sketchup for my first attempt for a couple of ideas.
Now I could do with a bit of advice….
First…. What do you think is best? Do I have my room arranged in the best way?
Second….In my design where I have moved the tv to the middle of a larger wall. I found out at the weekend that the wall sticking out is breeze blocks for support (I guess) from the original garage. Could I wall mount on this? and build a new frame to the same width as the tv so it looked better?
Third… Cabling. Where do you guys get your cables, plates etc from?
and last... does anyone know much about under floor heating?
Chris
Sony KDL46W40000 ~ Sony STR-DG520 ~ Sony BDP S300 ~ Sony Vaio VGN-N11M ~ XBOX 360 Elite ~ HD-DVD Add-on ~ Sky+
My gaming/office project...
Pont is offline   Reply With Quote
Old 12-08-2009, 3:37 PM   #2 (permalink)
Thanks: Gave 0, Got 16
Re: First attempt - My back room project
hi mate
you could mount the screen on that breeze block piller no probs , but have you thought about putting it on the wall where in the last pic you have the sofa and then put the sofa up against the piller what you was gona mount the screen on , if you get me lol
as for the under floor heating , not sure if you are aware but it dosent heat the room , it just basicly stops the chill on the floor so its warm under foot ,
youed be better off with some kind of wall mount heater or tryin to pick the flow and return pipes up from another rad in the house [perhaps in the room next door if theres one ]
i might not beable to reply tonight mate laptop is being fixed lol but il look on ere in the morning
hope this some help
thanks lockdown
lockdown81 is offline   Reply With Quote
Old 12-08-2009, 5:08 PM   #3 (permalink)
Thanks: Gave 23, Got 41
depends what you mean by underfloor heating. Electric basically warms the floor and the room slightly where as a wet system actually heats the room
kit list; samsung m87, ps3, xbox360, wii, onkyo 605, skyhd 160gb macbook, ae speakers(that really need upgrading), Sony hs50 projector, 8ft electric screen
http://www.avforums.com/forums/home-...73-i-made.html
deansocial is offline   Reply With Quote
Old 12-08-2009, 9:13 PM   #4 (permalink)
The other wall isnt very strong as its plaster board. I thought supporting the tv there would mean building a frame so it would take up more space. If I use the breeze block piller then I can build the frame around it.
Actually I just had a sit down in the room... It feels better to have a chair and then the desk next to each other. Also the door opens inwards in the room meaning the small sofa wouldnt be centered in the room... I guess I could knock out the existing plaster in the middle, put more support in then plaster it back up??
Electric underfloor heating doesn't heat the room? Oh well.... lol.
I was looking at panel heaters today and they seemed a cheaper option. Dimplex seem to have a couple that look modern and would fit in the room.
Cheers for the help.
Originally Posted by lockdown81 View Post
hi mate
hope this some help
thanks lockdown
Old 13-08-2009, 1:54 AM   #5 (permalink)
MarkP80's Avatar
Thanks: Gave 91, Got 76
I'd agree with lockdown's suggestion, put the tv on the wall where you currently have the sofa, and sofa where the tv is shown. You'll have a much better chance of getting the tv centrally aligned with the sofa too.
One way to mount the tv on a stud wall is to find where the vertical studs are and span between them with a piece of ply. The ply screws securely to the studs and you can fix the tv bracket to the ply. You can obviously paint the ply to match the wall, but it's hidden behind the tv anyway.
Another way is to cut the plasterboard out, fit noggins between the studs to fasten the bracket to, then replace the plasterboard and skim, but it's a fair bit more hassle.
If you're going to lay laminate, then consider taking the skirting board off. If you do this, you have a good chance of being able to feed cables to your tv down the inside of the stud wall, then under the floor and out where your kit is placed - probably in the spot where you show the desk. Same for your front speakers. Replace the skirting when you've done the floor, which means you don't need to fit any moulding.
Cheers,
MarkP
My Cinema and the Bar!
MarkP80 is offline   Reply With Quote
Old 13-08-2009, 8:30 AM   #6 (permalink)
How would I find the vertical studs? Tap the wall with a hammer then draw it out on the wall?
Old 13-08-2009, 9:30 AM   #7 (permalink)
i presumed the electric underfloor heating then the wet due to no rad pipes in there plus less work for the guy
Old 13-08-2009, 9:39 AM   #8 (permalink)
or just drill a few small holes in the plasterbored till you pick a stud up , you will proberly find them with the hammer , or drill the holes out behind the screen for the cables to pass down and put a rod or ruler in the hole and push it to the side untill it hits a stud , it wont be far from the hole lol ,, pop the skirtin off run all your cables [may need to chanel out across the floor ] put your floor down then pop new skirtin or even the old stuff back on then fill and paint ,, it will be so much easyer and look loads better and more central to have it on that wall
Old 13-08-2009, 3:30 PM   #9 (permalink)
Thanks lockdown, I will get my drill out on saturday and investigate.
With the cables.. I should have said that I also have access to the (sort of) loft area above. I'm going to crawl up there on saturday. If its possible shall I go up and over instead with the cables? This will mean longer ones though.
Old 13-08-2009, 6:17 PM   #10 (permalink)
yes mate you could run them up in the loft , a lot less work then a channel in the floor lol , good luck mate
Old 15-08-2009, 9:43 AM   #11 (permalink)
hi mate if you need any advise today il probably be about on here , il keep an eye out
good luk mate
Old 16-08-2009, 4:43 AM   #12 (permalink)
MarkP80's Avatar
Hi Pont,
What is the construction of your floor? Is it concrete or boarded?
You are likely to be needing some additional electrical outlets for all your AV gear and PC. I see there's a couple of sockets there already, so it's likely to be on a ring. To get additional sockets you are going to need access to the existing electrics (and you'll also need power to the TV), so this may influence the route you take with your AV cables. If you have the floor up to add sockets, you may as well run your AV cables at the same time!
Make sure you put in all the ones you are likely to need to your TV. If it has two HDMI sockets, I'd put two HDMI cables in as well.
Cheers,
MarkP
Old 16-08-2009, 2:21 PM   #13 (permalink)
Hi Guys,
Thanks for the responses. ..I've been up there now and crawled around. Heres two pictures...
I managed to find the stud in the middle of the wall... below is a pic after I filled a few holes back up and penciled out where I found it.
I also took the carpet out and found the floor to be boarded...
Going from the center line up the wall I drilled a small hole in the ceiling to see where it was up in the loft. Here's where I found it.. (second pic at the start of the paper like tear)
Now going off the last picture I found that there wasnt much room from the wall to the wood. Also if I followed the blue plastic it was more wood for the frame. I think it would be quite difficult to drill holes and with the amount of wires I need (hmdi, component, audio, vga) I'm not sure if this is the best way.
What do you guys think?
Old 16-08-2009, 4:11 PM   #14 (permalink)
hi mate has that wall got stud behind ??? are you sure its not dot and dabbed ?? only sayin cos from the loft it looks like an outside wall ?? or is it an outside wall but its got batterns fixed to it then drylined ??
if you not got alot of room behind the plaster board you might be best to make some chanels in the board or go downwadrs if that floor is hollow under it
Old 16-08-2009, 5:26 PM   #15 (permalink)
Thanks: Gave 603, Got 515
I hope your wrong their matey as I`ve got it all over my house without any other source of heating and it luvvly n warm.
Or maybe its because I`ve gone and dug a basement, i`m nearer the earths core and its that whats doing the heating
See my selfbuild/basement cinema...Part 1 Big Al`s Big Basement Build Bonaza... Part 2
JVC HD350-Onkyo 905 MK SW150s MK SW95s MK SW85s MK MX5100 SF MONSTER 118" fixed screen-Harmony 1000-HTPC 8TB
albriscoe is offline   Reply With Quote
attempt, back, project, room
