Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 01-12-2003, 5:33 PM   #1 (permalink)
robocop's Avatar
Thanks: Gave 0, Got 3
Question C5 Connector (cloverleaf) req'd
I'm after making a new lead for my AE300 projector. The problems is I can't find anyone that sells rewirable C5 connectors.
These are the same that are used on laptops etc, but they all come with a moulded plug.
Anyone have any ideas?
I want to use it with Supra Lorad cable.
"Come quietly or there will be ......trouble"
robocop is offline   Reply With Quote
Old 28-07-2004, 9:28 AM   #2 (permalink)
from a newbie with an AE500 to wire up to the ceiling this weekend!
Could you locate a rewirable kettle lead type IEC connection and then buy an adapter such as this one?
http://www.powertraveller.com/acatalog/Power.html
I'm thinking of putting a power socket in the ceiling and then making a custom length power cable so as to minimise the length of cable from the power socket to the back of the projector - is it worth buying a fancy bit of kimber cable or the like for such a short run? I don't want to spend a substantial amount of money but if there's a material picture improvement then I'll consider it.
Craig Armstrong is offline   Reply With Quote
Old 28-07-2004, 3:27 PM   #3 (permalink)
AMc
Thanks: Gave 10, Got 28
I couldn't find rewireable plugs when I looked or longer leads - the best I managed was a c5 connector prewired with no plug from www.cpc.co.uk which is the same as hacking the end of your own power lead.
The lead on my Philips PJ isn't long enough to reach from an inverted wall mount to a wall socket directly underneath
My Flickr Pictures
Philips Bogart DLP Projector-Sony KV32FX60U-Thomson Tivo-Wharfedale DV832BN(2) Freeview-Toshiba SD330E DVD-
-B-Tech Quintro+-Denon 2105 receiver-Canton CD1+CD50+CD100 Playstation3-Philips Pronto
AMc is offline   Reply With Quote
cloverleaf, connector, reqd
