Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray Review
Léon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray Review
Orange contract question sibbs07 Mobile Phones and PDAs 115 10-08-2009 11:34 AM
Dumb question? Does ITV HD have a proper channel and where is LuxeHD please? Mel_P Freesat 11 09-08-2009 4:12 PM
Electrical question Shoka General Chat 26 07-08-2009 10:01 PM
Weights + Dumbells - Noob question NISMO General Chat 19 07-08-2009 11:29 AM
OK Newbie Question U's will have heard a 1000 times B4 ageinghippy Sounds Cards, Mics, Headsets and Computer Speakers 27 07-08-2009 8:40 AM
Old 07-08-2009, 10:14 AM   #1 (permalink)
Projection screen pelmet- painting question
I am in the process of remodelling the Home Cinema in our living room. I have a manual screen which I have mounted and built a mdf pelmet around using 12mm mdf. I have fixed colour changing led spotlights to it. My question is about painting the mdf. The pelmet is fully built now, with the lights wired etc.
I have now read somewhere that I ought to paint both sides of the mdf to stop it from bowing. Is there a way to avoid having to do this, how likely is it to bow when the paint dries? Obviously, the last thing that I want to do is take it down again, it was a pain to build on the ceiling as it was.
I was going to use Crown standard wood primer, followed by top coat(s) of Craig & Rose Opulence soft suede textured paint in a Dark Chocolate colour, both of which I have already bought, it is a water based paint. Is it ok to paint the mdf with these?
I would be grateful of any advice about my questions or any aspects of painting mdf, its not something I've done before.
djc45 is offline   Reply With Quote
Old 08-08-2009, 4:30 AM   #2 (permalink)
MarkP80's Avatar
Thanks: Gave 92, Got 77
Re: Projection screen pelmet- painting question
The problem you have with MDF is that it absorbs water and swells. To avoid this you need to seal it, particularly the edges. You can buy proprietary MDF sealer, they have it in B&Q. It's not that cheap but I found it to work effectively.
Have a look here
Cheers,
MarkP
My Cinema and the Bar!
MarkP80 is offline   Reply With Quote
painting, pelmet, projection, question, screen
