Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
if any body needs advice on building work lockdown81 Home Cinema DIY 196 20-11-2009 8:15 PM
Long HDMI to bedroom TV... Les E HDMI Cables and Switches 8 06-08-2009 9:37 PM
My bedroom setup! Avidjames Members' Home Cinema Gallery 22 02-08-2009 10:11 PM
Wall bracket for M&K SS150 Mark 1 Mr_Orange Speakers 1 02-08-2009 9:57 PM
Old 02-08-2009, 11:29 PM   #1 (permalink)
Bedroom Wall Mount Build
Hi new user here, been looking through the forums at some excellent home cinema setups, now i am after my tv mounted on my bedroom wall with a floating type wall. Now the wall i want to mount the tv on is a partition wall but i havent got a stud locator. Now i am thinking of building a stud frame with say 4 x 2 timber and mounting the TV bracket on some 2 x 1 which will be attached to the stud frame which wil be all attached to the wall. Then MDF it over so that the tv is protruding from the frame by an inch or so. Would this be strong for my 32 inch tv.
my TV
The Wall
sorry for the rubbish pictures and the messy room.
I am wanting something like this users design Bedroom set up.. floating wall etc.. and going to paint it to match my blue wall. Also any ideas are welcome.
Matt
mattbrfc is offline   Reply With Quote
Old 03-08-2009, 5:59 PM   #2 (permalink)
Thanks: Gave 0, Got 10
Re: Bedroom Wall Mount Build
You'll need to screw the frame to the wall, if it's a stud wall then you'll catch about 3 uprights I'd imagine... Might be worth cutting a large piece of 12mm ply wood across the width of the frame screwed directly to the wall with as many beam fixings as you can get, you could then fix your TV mount to this (make sure you get some screws through the mount, plywood and into beams as well as into the ply)..
32" tv should be relatively light
Bear in mind you'll ideally want a slim flat-to-wall type hook mount else you'll have to build the frame out quite far from the wall which won't look as good.
Hope that helps a little and good luck
SparksCW is offline   Reply With Quote
bedroom, build, mount, wall
