Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray Review
Léon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray Review
Back to Plasma after 3 years! Bought a TH58PZ800 thudspud Plasma Televisions 27 28-07-2009 3:29 PM
Using the wall to project on to - what paint should I use? DrJarmin Projectors 15 28-07-2009 12:11 PM
Bedroom set up.. floating wall etc.. SparksCW Members' Home Cinema Gallery 16 28-07-2009 11:16 AM
37" TV - Good for Wall Mounting Shin-Ra Which LCD TV Should I Buy? 12 27-07-2009 6:51 PM
Acer Laptop - Samsung HD Plasma T.V. kath131 Laptops and Mini PCs 0 27-07-2009 6:17 PM
Old 27-07-2009, 7:39 PM   #1 (permalink)
Thanks: Gave 26, Got 28
Mounting Plasma on the Wall
Evening all,
I am moving into a rented flat on Thursday and I want to wall mount my Pio. I am not 100% sure what type of wall it is (it will in interier front room to Kitchen wall) but the landlady says it is solid and pretty much ruled it out being a stud wall.
This leaves us 3 options:
1. Get lucky and find there is a small gap between the plasterboard and the brick, giving room to drop the cables down.
2. Chisel out the plaster, and hide the wires in the wall.
3. Trunking on the outside of the wall.
The main problem we have is this wall is wallpapered, so we are going to have to strip and paint the whole wall if we end up 'going in the wall'.
This is my first choice but the landlady isn't too happy with us stripping the whole wall so unless I can convince her otherwise I am going to have to use trunking.
Is it safe to put the HDMI and power cables alongside each other down the trunking (either down the wall or in the wall).
Can somone recommend the best place to get in wall or exterior trunking?
Sorry for the long post
jwalsh82 is online now   Reply With Quote
Old 27-07-2009, 8:50 PM   #2 (permalink)
alexhodge1234's Avatar
Thanks: Gave 17, Got 29
Re: Mounting Plasma on the Wall
Originally Posted by jwalsh82 View Post
Evening all,
Since your renting the flat i would go down the route by using trunking to hide the cables. Keeps the landlady happy.
Do it when you get your own place and can do what you like lol.
I see loads of people running the power and video/audio cables in the same piece of trunking. It should be fine :D
alexhodge1234 is offline   Reply With Quote
Old 27-07-2009, 9:08 PM   #3 (permalink)
Thanks: Gave 23, Got 41
also when you do mov you dont have to buy new cables
kit list; samsung m87, ps3, xbox360, wii, onkyo 605, skyhd 160gb macbook, ae speakers(that really need upgrading), Sony hs50 projector, 8ft electric screen
http://www.avforums.com/forums/home-...73-i-made.html
deansocial is offline   Reply With Quote
Old 28-07-2009, 8:15 AM   #4 (permalink)
That is very true. The good thing I have is my best mate is a plasterer so he said he would do it for me, and it wouldn't take very long.
So for trunking, where is the best place to look. I assume B&Q e.t.c would be the best places, unless there is a retailler on here?
Old 28-07-2009, 8:18 AM   #5 (permalink)
mossym's Avatar
Thanks: Gave 198, Got 454
b&q do d-line which is very good..plus they do cheaper stuff....if you get teh cheaper stuff and want to paint it. give it a rub with some sandpaper first, really helps takes the shine off to let the paint take..i used it in mine
My Home Cinema Room
My Gear: 108" Carada Screen, Panasonic AX100, Denon AVR3808, 7.1 B&W 6 Series speakers, Panny BD35(now Region free for Blu-ray!!), HTPC, XBOX 360, WII
mossym is online now   Reply With Quote
mounting, plasma, wall
