26-07-2009, 10:19 PM
#1 (permalink)
| | Member
Thanks: Gave 7, Got 6 | Hiding holes in a wall - what is this?
Anyone know what that box is that the bloke in the pic is using to hide the jagged hole he's cut in the wall?
Better shot of it here at the 01:25 and 03:00 min marks. How to Wall Mount a Plasma: 12 steps (with video) - wikiHow (scroll down)
26-07-2009, 10:53 PM
#2 (permalink)
| | Senior Member
Thanks: Gave 360, Got 283 | Re: Hiding holes in a wall - what is this? Quote:
Originally Posted by md99 | Its a cavity wall pattress/back box with holes pre scored for knocking out to enable the cable to be fed through. The box is secured by two lugs with two screw holes which the faceplate is screwed onto, as the screws are tightened the lugs grip the inside of the stud wall/cavity ensuring a secure fit. One type of faceplate is a brushed one which looks like the rear of a letter box, this allows the cable to run freely and finishes the job off. PM an AVF member 'albriscoe' as he makes the brushed faceplates as a hobby. B&Q | nextday.diy.com - 12,000+ DIY products next working day delivery
Duncs
Assorted gear: Panny 42TH PX70, B&W Speakers, Kef HTB 2 Sub, Linn Diskreet speakers, multiroom Sky+ HD, PS3, Tosh EP30 HDDVD, Acer iDea 500 HTPC, Sennheiser HDR-120s, network gubbins, Xbox360s, Wii, Harmony 525, 360 & One. My Av-centric home
26-07-2009, 11:14 PM
#3 (permalink)
| | Member
Thanks: Gave 7, Got 6 | Re: Hiding holes in a wall - what is this? Quote:
Originally Posted by dunks517 Its a cavity wall pattress/back box with holes pre scored for knocking out to enable the cable to be fed through. The box is secured by two lugs with two screw holes which the faceplate is screwed onto, as the screws are tightened the lugs grip the inside of the stud wall/cavity ensuring a secure fit. One type of faceplate is a brushed one which looks like the rear of a letter box, this allows the cable to run freely and finishes the job off. PM an AVF member 'albriscoe' as he makes the brushed faceplates as a hobby. B&Q | nextday.diy.com - 12,000+ DIY products next working day delivery
Duncs | Thanks for that. Very comprehensive
One thing though, I've google image searched pattress boxes and all of them have a solid back. The one in the video clip is basically a square box with no back and a 'frame' around it to hide where the wall was cut. Same thing?
27-07-2009, 12:28 AM
#4 (permalink)
| | Senior Member
Originally Posted by md99 Thanks for that. Very comprehensive
One thing though, I've google image searched pattress boxes and all of them have a solid back. The one in the video clip is basically a square box with no back and a 'frame' around it to hide where the wall was cut. Same thing? | The back can be cut right out to accommodate large/thick cables, this is easily done with a hack saw or a pair of pliers (if not too fussy(, although the second method may leave a rough finish.
Assorted gear: Panny 42TH PX70, B&W Speakers, Kef HTB 2 Sub, Linn Diskreet speakers, multiroom Sky+ HD, PS3, Tosh EP30 HDDVD, Acer iDea 500 HTPC, Sennheiser HDR-120s, network gubbins, Xbox360s, Wii, Harmony 525, 360 & One. My Av-centric home |
27-07-2009, 1:01 AM
#5 (permalink)
| | Member
Thanks: Gave 92, Got 77 | Re: Hiding holes in a wall - what is this?
As Duncs says, just cut the back of the box out to suit your requirements, but these aren't designed to be a final finish. They're just the backboxes designed to fix onto a plasterboard wall. The brush faceplate Duncs mentions then simply screws over the front.
The point of my post was to say that these are rather expensive to buy from computer network specialists, but I noticed Wickes now sell them as well, so worth a look in there if there's one near you. You'll be able to get the backbox there as well.
MarkP
