22-07-2009, 12:05 PM
#1 (permalink)
Thanks: Gave 1, Got 0
Varilight remote control / touch Dimmers
Could anybody who's installed one of these before offer some advice?
Picked up one yesterday in B&Q for £5 and wired it up in the socket as normal for a single bulb, but it's just flickering like mad (like a strobe) without anyone even touching it to switch it on and also wont let me turn it off or adjust it!!!
Took it back and got another, but it's doing the same thing.
The bulb in the room is an energy saving one if that's the problem... or is it coincidence that both dimmer switches are knacked?
Many thanks in advance!
22-07-2009, 12:19 PM
#2 (permalink)
Thanks: Gave 5, Got 22
Re: Varilight remote control / touch Dimmers
Nice one B & Q. What colour are they?
These dimmers don't work with energy efficient bulbs, pity, great deal.
Carl
22-07-2009, 12:46 PM
#3 (permalink)
Carl
Cheers for that - will try it with regular bulbs later
They had two colours in their clearance bins (electrical dept); A gunmetal colour (Nickel?) and white, both were £5. I think the regular price instore is £32 & £20 respectively, so a steal if you can find them. 12 month guarantee too.
Just need to find a remote for the blighter now... if I can get it working!
22-07-2009, 12:56 PM
#4 (permalink)
Thanks: Gave 35, Got 15
you know you can train it to any infra red remote you have at home already?
22-07-2009, 2:43 PM
#5 (permalink)
I didn't but I'll certainly be looking into it now - thanks for the heads up
22-07-2009, 2:45 PM
#6 (permalink)
Thanks: Gave 198, Got 456
have one of these in my cinema room, have my harmony controlling it...harmony database has the codes for the actual varilight remote you can get in it
My Home Cinema Room
My Gear: 108" Carada Screen, Panasonic AX100, Denon AVR3808, 7.1 B&W 6 Series speakers, Panny BD35(now Region free for Blu-ray!!), HTPC, XBOX 360, WII
22-07-2009, 6:26 PM
#7 (permalink)
Thanks: Gave 1, Got 4
Carl
Yeah unfortunately you cannot dim energy bulbs with any dimmer.
22-07-2009, 6:41 PM
#8 (permalink)
Thanks: Gave 5, Got 3
That's no quite true  Dimmable low enery buld do exist now. A quick google should show them up. I know that screwfix and some other diy outlets stock them now. The price difference from normal ones has come down quite significantly in recent times.
22-07-2009, 6:48 PM
#9 (permalink)
Thanks: Gave 23, Got 41
you can dim low energy bulbs but not with electronic dimmers
22-07-2009, 9:56 PM
#10 (permalink)
Changing the bulb for a regular 60w fixed it - Cheers again , never knew that about dimmers!
