Free electronics advice and information
3.5 million visitors each month
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Sherlock Holmes Blu-ray ReviewClash Of The Titans - Original Motion Picture Soundtrack CD ReviewZombieland Blu-ray ReviewLast King of Scotland, The Blu-ray ReviewAfrican Queen, The Blu-ray Review
Cirque du Freak: The Vampire's Assistant Blu-ray ReviewToy Story Blu-ray ReviewClash Of The Titans Blu-ray ReviewVengeance Blu-ray ReviewHellboy Animated: Sword Of Storms/Blood and Iron Blu-ray Review
Thread Thread Starter Forum Replies Last Post
Quick Question... nokmond Home Entertainment PCs 4 21-07-2009 9:11 PM
Xbox 360 Quick Charge Kit - White (Xbox 360) - £14.98 Rick Shaw Gaming Bargains and Discount Codes 3 21-07-2009 12:07 PM
Quick question - Receivers that upscale Analogue Video. friddela AV Amplifiers and Receivers 1 20-07-2009 8:55 PM
Old 21-07-2009, 7:53 AM   #1 (permalink)
googlebox99's Avatar
Thanks: Gave 9, Got 10
Quick mounting question (bolts)
I am mounting a Toshiba 37" WLT66 into solid brick.
I was going to use screw fixings supplied with the mount, but the heads were terrible and were mashed up easily by my screwdriver!
So, thought I would go and buy some anchor bolts.
Holes are already drilled - 10mm diameter. Would 4 x anchor bolts be sufficient and do I need M6 or M8?
Maximum depth of bolt/screw is 70mm (unless I buy a bigger drillbit).
e.g.:
Fischer Bolt Type Shield Anchors M8 x 65mm Pack of 5 - Screwfix.com, Where the Trade Buys
Fischer Bolt Type Shield Anchors M6 x 60mm Pack of 5 - Screwfix.com, Where the Trade Buys
I have an M6 in front of me which fits in the hole nicely, but wondering if I need to get M8.
googlebox99 is offline   Reply With Quote
Old 21-07-2009, 8:51 AM   #2 (permalink)
chienmetallique's Avatar
Thanks: Gave 5, Got 28
Re: Quick mounting question (bolts)
Go for 100mm for when you upgrade to 50".
Carl
chienmetallique is offline   Reply With Quote
Old 21-07-2009, 8:52 AM   #3 (permalink)
From some research I think I will go for the M6 anchor bolts which will fit perfectly my 10mm hole.
They are 60mm long - any idea if 4 will be sufficient or if I should make it 6/8?
Old 22-07-2009, 2:33 AM   #4 (permalink)
MarkP80's Avatar
Thanks: Gave 97, Got 96
- The important point is that the holes should be the diameter that is specifiied for the particular anchor used. What size hole do the instructions say for your anchors? They should be a reasonably snug fit in the hole, or the anchor will not grip when tightened. Provided the correct anchor grip is achieved, then 4 M6 anchors will be fine.
MarkP
My Cinema and the Bar!
MarkP80 is offline   Reply With Quote
Old 22-07-2009, 6:11 AM   #5 (permalink)
Thanks: Gave 24, Got 48
as long as you drill deeper than the anchor and clean the hole out then they will be fine.
kit list; samsung m87, ps3, xbox360, wii, onkyo 605, skyhd 160gb macbook, ae speakers(that really need upgrading), Sony hs50 projector, 8ft electric screen
http://www.avforums.com/forums/home-...73-i-made.html
deansocial is offline   Reply With Quote
bolts, mounting, question, quick
Copyright © 2000-2010 M2N E. & O. E.
