Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
French TV5 on hotbird ben67 Satellite TV 2 21-07-2009 4:29 PM
Upgrading Front Door Speakers, Do I need to upgrade the cable too? Tfish In Car Entertainment (ICE) 4 21-07-2009 6:54 AM
Old 20-07-2009, 5:54 PM   #1 (permalink)
Thanks: Gave 0, Got 4
French door blackout...
I have french doors at the end of my living room. There is the 2 doors, then windows either side. I wish to get some blackout blinds of some sort so that I can use my projector properly in the day. Has anyone fitted then to these doors before? I want something that can be up when they are not is use and also looks reasonable lol
Woody26 is online now   Reply With Quote
Old 20-07-2009, 6:05 PM   #2 (permalink)
soupdragon's Avatar
Thanks: Gave 35, Got 15
Re: French door blackout...
whats the combined distance across from 1 side to the other (including doors and windows)?
http://www.avforums.com/forums/membe...e-theatre.html (my 1st home theatre link)
soupdragon is offline   Reply With Quote
Old 20-07-2009, 7:02 PM   #3 (permalink)
It measures 101 inches
Old 20-07-2009, 9:59 PM   #4 (permalink)
soupdragon's Avatar
i would be enclined to get 1 big roller blind, if all its going to be used for is blocking light at movie time then that would be the cheapest option....just remember to have it set out far enough that it misses the door handles on the way down...
if you have to screw into the door frame, stay at least 2.5 inches away from the glass as it sits quite a bit inside the frame...
as for types of blind, ikea has really cheap ones, but not 101 inches....
try this...
Amazon.co.uk: Used and New: WHITE 240cm wide x 160cm blind. 100% Blackout roller blinds. (More colours available)
Old 21-07-2009, 2:43 AM   #5 (permalink)
MarkP80's Avatar
Thanks: Gave 92, Got 77
My Mrs made a simple blind for our cinema room. She just bought some blackout material and cut it to size, ran a curtain wire through the top with hooks and added a weighted rod to the bottom. We just have small eyes screwed into the door frame. When we use the cinema we just hang them up. They roll up around the weight rod for storage.
Might be a bit simple for what you want, but it works well, although it might be a pain if you are doing it every day (it is very easy though, and they just go under the sofa in the cinema). It suits us as it means there is no fixed blind visible on the doors, which she didn't really want. OK, there's a little leakage around the edge, but not significant for us, depends what you are looking for really. As I say, Mrs MarkP REALLY didn't want a blind fixed in place so this was an option for me as a cheap compromise.
Cheers,
MarkP
My Cinema and the Bar!
MarkP80 is online now   Reply With Quote
Old 21-07-2009, 5:41 PM   #6 (permalink)
Cheers,
MarkP
Hmm I may have a look at this, sounds quick/simple and cheap!
blackout, door, french
