Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray Review
Léon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray Review
Windows Home Server Power Pack 3 Announced Singh400 Windows Home Server 14 17-11-2009 10:11 AM
Full-HD 160" Screen 7.1 setup in my living room daviddekanter Members' Home Cinema Gallery 155 08-10-2009 2:27 PM
Mobz' Home Cinema 'work in progress' MRMOBEUS. Members' Home Cinema Gallery 31 23-07-2009 12:37 PM
Using 2nd router as wireless boost daniel_owen_uk Networking and NAS 8 20-07-2009 9:47 AM
Old 20-07-2009, 11:10 AM   #1 (permalink)
soupdragon's Avatar
Thanks: Gave 35, Got 15
my 2nd home theatre, bar, pool room via garage conversion
hi guys
just completed my 1st home cinema inside my house - its a stop gap until i complete my garage conversion. i moved into this house last summer and nearly had an accident in my pants when i seen the garage they built
its a storey and a half, 19'6" x 13'2". the upstairs has a 7ft high ceiling.
its my expectation that i'll be starting this project in 2011, but the planning is very important, so i'm starting this now. there is a lot of experience on these forums, this type of project is new to me, so i would be grateful to people for their expertise and ideas, along with estimates of how much things cost (i've no idea yet of how much the conversion will cost)
a few questions:
the garage walls have no cavity, built with breeze blocks on inside and screened - do i need additional insulation to keep the heat in?
the oil burner is in the garage, can i just feed some radiators of this?
the garage has a seperate fusebox, can i just rip this out and put in a bigger one for my lighting, plug points etc..?
theres a drain under the gutter spout, is it ok to feed toilet waste into this?
the walls have a harsh, cement type screening on them, can i just pin plasterboard onto this, or do i need to build a stud wall 1st?
thats a lot of questions, if you can help me with even 1 of the questions, i would be very grateful as my knowledge in this area is not good at all!
my current cinema link:
my 1st home theatre
pics...(plan is for the cinema upstairs and below will be the pool room/bar)
my 2nd home theatre, bar, pool room via garage conversion-dsc00170.jpg   my 2nd home theatre, bar, pool room via garage conversion-sany0108.jpg   my 2nd home theatre, bar, pool room via garage conversion-sany0109.jpg   my 2nd home theatre, bar, pool room via garage conversion-sany0118.jpg   my 2nd home theatre, bar, pool room via garage conversion-sany0117.jpg
my 2nd home theatre, bar, pool room via garage conversion-sany0110.jpg   my 2nd home theatre, bar, pool room via garage conversion-sany0119.jpg
http://www.avforums.com/forums/membe...e-theatre.html (my 1st home theatre link)
soupdragon is offline   Reply With Quote
Old 20-07-2009, 11:38 AM   #2 (permalink)
Thanks: Gave 368, Got 63
Re: my 2nd home theatre, bar, pool room via garage conversion
That's a great space! - BatBarn 2 in the making. I would search for the batbarn thread as it looks very similar to what you have, i am sure all your answers will be in there or just ask the op
Cinema room spec: [eyes] Planar PD7010 - [ears] Samsung HTZ310R - [Heart] PS3
My Cinema Room Build...
deefadog is offline   Reply With Quote
soupdragon (20-07-2009)
Old 20-07-2009, 2:53 PM   #3 (permalink)
soupdragon's Avatar
thanks deefadog
thats a gr8 thread, especially like the subs
i've edited the original post to leave only my unanswered questions...
any help is appreciated
Old 20-07-2009, 4:08 PM   #4 (permalink)
Thanks: Gave 603, Got 516
Originally Posted by soupdragon View Post
a few questions:
I think you mean screeded mate not screened
I am sure that if you don`t build an internal stud and plasterboard wall with insulation, at least 100 mm you`ll wish you had. This is also same for the roof as well as all your expensive heat will go out through their.
Also in doing this its a chance to run and hide all your cables as well.
Don`t see why not, you might want to pump it separatley so you don`t have it heated when not in use, not a difficult job really but cost effective in the long term.
Depends really, you`ll have to find out how its fed and what with,ie. size of cable and circuit breaker.
Only if you want to end up in court for pollution
If your house has a combined drainage system then it is possible to allow fowl water to go into the existing drains but only done with proper underground soil pipes ie. 4".
You will also need inspection chambers as well for rodding purposes.
If it has like most houses a separate clean water and fowl water system then you must not under any circumstances put fowl water into the clean water drainage and will be severely fined if caught doing it.
As in answer 1 I would build a stud wall first. this will also help with damp problems as well.
2 other questions now for you
What size ceiling joists are up their at the mo, are they up to spec for having a proper floor and furniture on them and correctly spaced.
And last but not least, when you`ve spent all this money on the conversion and your chuffed to bits with it you will make sure that the local council have passed it all for change of use and req`d planning consent has been aquired.
I`d hate to happen to you mate so have a think about it.
cheers Al
PS. You owe me a pint
See my selfbuild/basement cinema...Part 1 Big Al`s Big Basement Build Bonaza... Part 2
JVC HD350-Onkyo 905 MK SW150s MK SW95s MK SW85s MK MX5100 SF MONSTER 118" fixed screen-Harmony 1000-HTPC 8TB
albriscoe is offline   Reply With Quote
Old 20-07-2009, 6:17 PM   #5 (permalink)
soupdragon's Avatar
gee thanks albriscoe - thats a comprehensive answer to my q's
in terms of beam widths i'm not sure but it was built with the purpose of an additional storage - i guess i'll need to go out and measure them...
in terms of planning permission....
thanks for the advise there....could have been costly!
Old 21-07-2009, 3:03 AM   #6 (permalink)
MarkP80's Avatar
Thanks: Gave 92, Got 77
- Are you sure about the construction? The photo of the wall taken showing the doorframe looks rather thick.....
- usually at least twice what you think it will cost when you first start, in my experience!!!!
Cheers,
MarkP
My Cinema and the Bar!
MarkP80 is offline   Reply With Quote
Old 21-07-2009, 9:01 AM   #7 (permalink)
The door openings Mark are usually double brick to support a lintel above, I know what you mean though they do look to be cavity width
Old 21-07-2009, 9:32 AM   #8 (permalink)
Paul_T's Avatar
Thanks: Gave 103, Got 404
Think i'll be subscribing to this thread - has the potential to be an epic.
Sony Bravia 52W5500 / XBox 360 Elite & Arcade / PS3 60GB / Logitech Harmony 555 / Sky+ HD / Sony STR DG820 / Bowers & Wilkins 601 S2 & CC6 S2 / KEF 1005's ... and a subwoofer with an Ikea cushion on it for a seat!
Paul_T is online now   Reply With Quote
Old 21-07-2009, 9:38 AM   #9 (permalink)
Paul_T's Avatar
Surely there is a cavity in the majority of the wall though - I'd have thought that the door jambs would have been built up as piers to support the lintel (is it one steel beam as I can't quite tell from the pics) along with a padstone.
It's quite common in garages though to have double skin on the front and rear walls and only single skin for the sides.
Old 21-07-2009, 12:59 PM   #10 (permalink)
You`ll have to ask the owner this but to save material costs and labour they might only be pillars to support the lintel.
ie; a brick and half or 2 bricks square.
Its also common to have vertical pillars along the length of a long wall but its not always seen.
The most important factors this guy has got is a. permission b drainage.
the rest can be overcome with time, effort, money and a bit of common sense
But it should make a great addition to his home if done correctly and from what I can see in the pics it looks like its been contructed to quite a high standard.
Old 22-07-2009, 7:02 AM   #11 (permalink)
soupdragon's Avatar
hi guys
there is definately no cavity, next door is part completed, built to the same spec and there is no cavity - looks like i'll have to make a stud...
as mentioned earlier, this will give me cable hiding options as well as insulation so i'm not totally upset by this.
i hope it does make a good read! i won't access any major funds until 2011 so progress will be slow until then
no harm in starting to plan though!
Old 22-07-2009, 6:21 PM   #12 (permalink)
Thanks: Gave 23, Got 41
do it in metal and insulate behind to lose the least room
kit list; samsung m87, ps3, xbox360, wii, onkyo 605, skyhd 160gb macbook, ae speakers(that really need upgrading), Sony hs50 projector, 8ft electric screen
http://www.avforums.com/forums/home-...73-i-made.html
deansocial is offline   Reply With Quote
Old 22-07-2009, 8:02 PM   #13 (permalink)
soupdragon's Avatar
hi
this may seem daft but...do what in metal? i don't understand what you mean..
Old 22-07-2009, 9:14 PM   #14 (permalink)
create a cavity with metal studdiing
Old 22-07-2009, 9:28 PM   #15 (permalink)
Lafarge Plasterboard UK : Home > Project Type
like this
2nd, bar, conversion, garage, home, pool, room, theatre
