Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Galaxy 60 problem Alarm in Engineer Mode? bis5 Home Automation, Lighting, Security, Heating and Cooling 13 28-07-2009 4:35 PM
Latest Nvidia Drivers Problem Officer M168 Graphics Cards, TV Tuners and Webcams 3 27-07-2009 7:50 PM
Goodman LD2667D, with Xbox Problem ryanalien Xbox 360 3 19-07-2009 2:05 PM
Sky+ recording problem Chrisblanchard Sky and Sky+ 8 18-07-2009 8:19 AM
Problems with Camcorder Canon MD160 Mrs.D82 Camcorders and Video Editing 1 17-07-2009 11:59 PM
Old 18-07-2009, 8:17 AM   #1 (permalink)
Thanks: Gave 117, Got 64
Overheating problem
Mods please move if in the wrong place.
TV entertainment system been built 55" gap for a 42" TV underneath that is a sperate 'shelf' which sits HTSS1300,SKY HD and PS3 - the gap arround each item is about 4" left and right and to the rear about 11" - but the PS3 is over heating and last night cracked a CD by overheating (googled).
I need to cool the air in and around, i was surprised at the amount of heat generated by all 3 items and its a concern.
From research this morning on Google the best idea upto now is to use some 12db PC fans - and hide them behind which will help generate an airflow while being discreet and quiet. However i am unsure on how to either connect these to a 13amp power supply (say a plug) and or to a usb device?
Good idea or does anyone have a better idea?
Regards
BDB
PSN: BB3Lions
www.helpforheroes.org.uk & http://ssafa.org.uk/
Brandon66 is offline   Reply With Quote
Old 18-07-2009, 8:25 AM   #2 (permalink)
Trollslayer's Avatar
Thanks: Gave 36, Got 151
Re: Overheating problem
I use 12cm Akasa fans on my AV receiver and run them at 5V, no noise at a decent price
Ultra Quiet 120mm Case Fan : Case Cooling : Maplin
Sky+ HD
Popcorn hour A110
Onkyo 606
Panasonic 42" plasma
Trollslayer is offline   Reply With Quote
Brandon66 (18-07-2009)
Old 18-07-2009, 8:27 AM   #3 (permalink)
Saw them this morning, can i ask how you power them? Did you cut and connect it to an old usb cable or ?
PSN: BB3Lions
Old 18-07-2009, 3:08 PM   #4 (permalink)
Thanks: Gave 17, Got 11
The PS3 actually cracked a CD because of the heat!? That's worrying!
Take a look at this post (goes directly to correct post):
My AV Forums inspired set-up...
Then take a look at the pics at the start of the thread. He used AV Cooler 'plate' type things which he says does the job!
simonprr is offline   Reply With Quote
Old 18-07-2009, 3:51 PM   #5 (permalink)
What i have done is bought a 18db ~PC (£5) fan from PCworld this morning and directly wired it to an old 12v power supply i had. Ive positioned it at the rear of the 3 devices so now its extracting air from below the surrounds and expelling the air past the 'inlets' of the devices, thus forcing cooler air from below to be sucked in.
Had the PS3 on for an hour and its alot cooler, so obviously i need to buy 3 or 4 more fans just because...
The fan works on a remote control - the ones you get from B&Q. running at 18db you cannot hear it at all which is a positive.
I'm in the lookout for dell PowerEdge fans, there circular in design and very very powerful, i'm thinking of having one as an inlet and one as an outlet on either side of the unit.
Edit@: forgot, the Fifa09 disc had a crack right in the centre point, it was not loading and when out to clean i noticed A the heat & 2 the hairline crack. After spending a few hours googling it is a known issue with a unit that overheats - 110'c and above.
PSN: BB3Lions
overheating, problem
