Thanks for all the help so far.
It looks like I have restricted myself by putting in a BT point rather than another RJ45 module into each faceplace. I could always change this later, I guess.
At the patch panel I will reserve 4 or so rj45s for phone usage. These should be commoned up so all the various colours are connected up.
I can reserve 8 ports on the patch panel for the phones, however I'm not sure how to "common all these up" - do I need to run wire between each coloured connector to the corresponding colour on each of the commoned RJ45's on the patch panel?
You should only need a REN amplifier if you plan on connecting up more than about 4 phones. Are you planning on doing this?
We will probably be running more than four phones on the system so there will have to be either a REN amp. I'll look into the switchboards - does anyone know the best place for them?
