Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Galaxy Quest Blu-ray ReviewMy Bloody Valentine - Special Edition Blu-ray ReviewThe Universe: Complete Season One Blu-ray ReviewTerminator Salvation Blu-ray Review20th Century Boys: Chapter 2 - The Last Hope Blu-ray Review
North By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray Review
KEF Speaker Summer Deals ashcurrie Home Cinema Hardware Bargains and Discount Codes 3 25-06-2009 1:38 PM
help with speaker set up to work with PC manaquin Hi Fi Systems and Separates 9 22-06-2009 9:35 AM
set up on samsung- air or cable when using sky hd ? gill957 LCD Televisions 4 22-06-2009 7:41 AM
Cinema speakers?? Prize78 Speakers 14 21-06-2009 11:49 PM
Old 21-06-2009, 9:58 PM   #1 (permalink)
Thanks: Gave 28, Got 1
speaker cable under wooden floor ?
Im going to be running some speaker cable under a solid wooden floor, the wood is 18mm thick and 150 mm wide planks.
Anyway below the floor will be the dpm sheet and then a solid concrete floor with those cheapo tiles on top, the sort you get before you would lay carpet on top.
To get to my question, is it ok to lay standard speaker cable under the wooden floor (2mm thick) or will i need to get the flat type of cable ?
Thanks to anyone who can confirm what i should do.
Brenda
Bbnm is offline   Reply With Quote
Old 22-06-2009, 5:44 PM   #2 (permalink)
Re: speaker cable under wooden floor ?
Hello,
Anyone care to clarify please.
Brenda
Old 22-06-2009, 7:03 PM   #3 (permalink)
Thanks: Gave 16, Got 105
Hows the floor fixed down? If its a floating floor there should be underlay under the flooring.
John..
27neth is offline   Reply With Quote
Old 22-06-2009, 7:31 PM   #4 (permalink)
Thanks: Gave 603, Got 516
Brenda
If your laying a new floor have you got the skirtings on yet, if not can`t you place the spk cables behind the skirting.
If the skirting is already on and the new floor butts up against it, you should leave a 10mm expansion gap which will be covered with a bead so leaving room for the cable their as well.
HTH`s Al
See my selfbuild/basement cinema...Part 1 Big Al`s Big Basement Build Bonaza... Part 2
JVC HD350-Onkyo 905 MK SW150s MK SW95s MK SW85s MK MX5100 SF MONSTER 118" fixed screen-Harmony 1000-HTPC 8TB
albriscoe is offline   Reply With Quote
Old 22-06-2009, 8:22 PM   #5 (permalink)
I did not from my research believe i needed a floating floor, just a glued down one ?
I'm intending on getting new skirting boards down as it looks better and negates the need for expensive beading, or tough sanding of existing skirting.
I was going to run the cable flat or otherwise to the preferred floorstanding location and then have the wire pop up through some grommets that will be inserted in the wood ?
The stereo speaker locations are giving me trouble at the moment, as per speaker thread on corner placement and rear or front ported !
So is flat cable the way to go ?
Thanks for your help.
Brenda
Old 22-06-2009, 8:43 PM   #6 (permalink)
If the flooring is getting glued down to the concrete floor i would not run any speaker cable under it. You need the concrete floor as flat as possible.
If you are fitting new skirting, you have to leave a expansion gap all the way around the flooring usually about 10mm, you can lay the speaker wire in the expansion gap before the skirting is fitted.
If you need the speaker wire running across the floor, i would get a angle grinder out
John...
Old 22-06-2009, 8:56 PM   #7 (permalink)
Thanks John,
So to the original question, will flat speaker cable taped to the membrane allow me not to chop ones fingers of with angle cutter ! lol
Brenda
Old 22-06-2009, 9:05 PM   #8 (permalink)
Hi Brenda,
If it was me i would either get a angle grinder or ask who ever is supplying or fitting the flooring if you can lay the speaker cable down.
I would not risk just putting it down, if something goes wrong the suppliers or fitters will probably blame you for it..
john
Old 22-06-2009, 9:08 PM   #9 (permalink)
Thanks: Gave 20, Got 23
When I put my wooden floor down - it is 15mm engineered oak, I layed 2mm breather membrane down, and then cut out sections of the membrane for the speaker wire to run between the wood flooring and the concrete floor underneath.
I am using QED Silver Anniversary wire and there is no problem with this - I think it is about 2 to 3 mm thick and there is no noticeable rise in the floor where the cable is. When I had carpet down, there was a very clear line where the cable was!
Hope this helps.
Per
Panasonic PT-AE2000 l Beamax 98" screen l Panasonic TH46PZ80 l Onkyo 875 l KefIQ9, IQ1, IQ6, SVS PB12+ l Panasonic BD50 l Pioneer pd-dj6 CD l Sky HD l Harmony895
Per156GTA is online now   Reply With Quote
Old 22-06-2009, 9:18 PM   #10 (permalink)
Right i think i can cut the membrane and tape it up leaving a gap, but allowing the membrane to be together as it were.
I might just run some flat type cable on top of the membrane.
My old friend is going to visit and do the floor along with many other jobs that i cant manage.
It will be ok, i think/hope ! lol
thanks
Brenda
Old 22-06-2009, 9:22 PM   #11 (permalink)
What is the membrane you are using? Is it solid timber flooring you are using or engineered? If its solid timber this is usually glued direct to the concrete floor, if its engineered you can just cut out strips of the underlay for the speaker cable to lie in.
John..
Old 22-06-2009, 9:33 PM   #12 (permalink)
Solid floor and im sure you stil use a dpm even with glueing ?
Brenda
Old 22-06-2009, 9:44 PM   #13 (permalink)
With solid flooring it glues directly to the concrete with a horrible resin type glue
John...
Old 23-06-2009, 2:34 PM   #14 (permalink)
hello,
Yes, DPM is a must with any concrete floor.
thats from one of the proposed suppliers ?
Brenda
Old 23-06-2009, 3:27 PM   #15 (permalink)
The dpm will only be a liquid, so there will be no room for speaker wire http://www.russwood.co.uk/flooring/d...odSikabond.pdf
John...
cable, floor, speaker, wooden
