18-06-2009, 7:39 PM
#1 (permalink)
Thanks: Gave 17, Got 21
Granite isolation under speakers, spike or not to spike!
I just did this diy upgrade (argos granite chopping boards  ) am quite impressed with the result sound wise (other reason was steadying my wobbly iQ5's on carpet, much better on solid flat surface)
BUT
this leads to another quandry...
Do I ditch the spikes on the iQ5's and put rubber dome pads underneath (to me seems better, will be dead flat without spike faffing adjustment, plus cant skate around on the granite surface)
What have you guys done with your floorstanders on granite platforms?
PSN ID - Kahuna2007
18-06-2009, 9:21 PM
#2 (permalink)
Thanks: Gave 165, Got 107
Re: Granite isolation under speakers, spike or not to spike!
Hi. Ive got some ms avanti 902i's on stands on spikes on granite downstairs.
I think they sound good.
Upstairs i have some XTZ' 93WMT's on their own Floor stand 99's (no spikes just rubber) and then on granite slabs from tescos.
To my ears, both setups definately improved using the slabs.
Particularly upstairs where the floor is boarded and leaks sound, the granite seems to both tighten and isolate the sound.
So i think its just down to your own ears really. see if you prefer with or without the spikes? p
Fluker
"It aint possible to live unless you crossing somebody's line..."
19-06-2009, 7:47 AM
#3 (permalink)
thanks P, definitely impressed with how its tightened up the sound noticed the difference right away
I think I might try some rubber feet apart from anything it will stop them being able to be moved so easily on the granite (plus lowering them a bit more than the spikes to making them less topple over-able)
Going to get another for for my sub now
PSN ID - Kahuna2007
19-06-2009, 1:47 PM
#4 (permalink)
cheers. I dont think youll notice any reduction in quality. And if you need them more secure then definately go the rubber route. Homebase sell some pretty good stick on rubber pads if i remember.
Ive also got my sub on one of the Tesco granite slabs.
Fluker
19-06-2009, 2:09 PM
#5 (permalink)
Thanks: Gave 7, Got 18
I had a look at the Tesco site last evening, but couldn't find any slabs other than the placemets......
STUFF: Samsung LE46A756, Denon AVR-2309, TMA 903MK-IV, Canton Movie 150 QX, Logitech Harmony 785.
HTPC: Silverstone LC13-E based HTPC, 2TB mirrored media server.
WIP: Building my own floating wall...
19-06-2009, 2:30 PM
#6 (permalink)
Thanks: Gave 10, Got 6
Argos do 1 for £7.49
Buy Metro Dark Granite Worktop Saver. at Argos.co.uk - Your Online Shop for .
Cheers for the tip lads I might try these with my 773's, the thing is Im about to rebuild my living room and put wood floor down so this will also protect my floor
Samsung 55" 7020, Denon1910, Mission M35i's, Mission 77C, Mission 760I, Yamaha YST-SW300 subwoofer , Xbox360, PS3, SkyHD
19-06-2009, 2:33 PM
#7 (permalink)
Originally Posted by ninja tattoo
yeah gutted! I bought 2 only a couple of days ago for £12 each! ah well I went down at lunch and bought a 3rd for my sub, granite a go go in my front room now
these will protect a wood floor too, they have 4 foam rubber feet on the bottom which will help isolate and extra vibration.
PSN ID - Kahuna2007
19-06-2009, 2:37 PM
#8 (permalink)
Thanks, allready found that one. Just asked pricing with a dutch company for 2 blocks of 300x300x400mm...
19-06-2009, 2:49 PM
#9 (permalink)
400mm thick is good should get no vibration through that, I would have preferred 300mm on the chopping boards but its not something I wanted to spend a fortune on and it has made a difference.
Other option is look for granite surface plates, variety of sizes (and prices) but they are usually at least 400mm thickness
PSN ID - Kahuna2007
19-06-2009, 4:08 PM
#10 (permalink)
Thanks: Gave 20, Got 22
You might mean 40mm thick!! 400mm is nealy 16 inches thick - good luck with lifting one of those!
Per
Panasonic PT-AE2000 l Beamax 98" screen l Panasonic TH46PZ80 l Onkyo 875 l KefIQ9, IQ1, IQ6, SVS PB12+ l Panasonic BD50 l Pioneer pd-dj6 CD l Sky HD l Harmony895
19-06-2009, 4:11 PM
#11 (permalink)
have you not heard of granite obelisk isolation platforms
PSN ID - Kahuna2007
19-06-2009, 4:11 PM
#12 (permalink)
Per
No I meant 400mm and that should weigh about 200kg...
19-06-2009, 4:15 PM
#13 (permalink)
Not until now!
19-06-2009, 4:15 PM
#14 (permalink)
19-06-2009, 4:17 PM
#15 (permalink)
But i'm not sure if it will be granite or a softer stone...
