3.5 million visitors each month
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Star Wars: The Clone Wars Blu-ray ReviewPublic Enemies - Original Motion Picture Soundtrack CD ReviewAudition Blu-ray ReviewPolice Story Blu-ray ReviewYear One Blu-ray Review
The Living Dead At Manchester Morgue Blu-ray ReviewPublic Enemies Blu-ray ReviewGojira Blu-ray ReviewHalloween II Original Motion Picture Score - Expanded 30th Anniversary Edition CD ReviewStar Trek - Complete Original TV Show Season 2 Blu-ray Review
Decaying Fireplace steved35 Past Entries 4 15-06-2009 3:41 PM
Mount TV over Open Fireplace - Examples Please ! eddiem74 Home Cinema DIY 18 30-05-2009 9:30 AM
Special sliding mount - above fireplace? googlebox99 Flat Screen TV Brackets and Mounts 2 29-05-2009 9:42 AM
LCD over fireplace? garagekru LCD Televisions 65 21-05-2009 11:45 AM
Mounting a LCD on the wall and removing a fireplace dangillow Custom Installations and Installers 6 17-04-2009 9:55 PM
Old 17-06-2009, 4:26 PM   #1 (permalink)
fireplace
Hi, I have removed the fire but I am now left with a hole that I wish to cover! but not permanently incase I decide to sell etc. so what's the cheapest way to hide the hole? thought about getting a fire surround, but I would still need to cover the hole up!
any ideas ;-)
plan to mount a TV above the mantle
topheruk is offline   Reply With Quote
Old 17-06-2009, 8:56 PM   #2 (permalink)
Re: fireplace
anyone!
Old 17-06-2009, 11:07 PM   #3 (permalink)
Thanks: Gave 9, Got 3
Re: fireplace
I'd just cut a board to sit flush in the hole (maybe have some timber in the hole to screw the board to) & plaster over it. Simples
Philips 50PFP5532D // infocus X2 (720p through component to M1) // JVC QP-112AL 5.1 amp // PS3 // Dreamcast // Wii // Pentium 4 3 GHZ 320gb Storage running TVersity / XBOX (with a broken ethernet port ) Runnig XBMC & all my retro games!
m7cky is offline   Reply With Quote
Old 19-06-2009, 2:38 PM   #4 (permalink)
ninja tattoo's Avatar
Thanks: Gave 10, Got 6
Re: fireplace
Ive a chimney breast that contains no fire at all just a huge 2x3 mt hole, Im planning on mounting my TV on the Chimney beast and drilling into the flue to drop cables down into the fireplace where I will box it out using plasterboard n get it re-skimmed, My TV stand with my AV hardware on will go into the fireplace with the front speakers on the opposite side of the breast.
Can you not put all your AV stuff into the hole? ie box it out and use it as a shelf?
Samsung 55" 7020, Denon1910, Mission M35i's, Mission 77C, Mission 760I, Yamaha YST-SW300 subwoofer , Xbox360, PS3, SkyHD
ninja tattoo is offline   Reply With Quote
Old 19-06-2009, 2:46 PM   #5 (permalink)
M.D. Klapwijk's Avatar
Thanks: Gave 7, Got 18
Re: fireplace
I would asure myself that the enclosure for the av hardware is waterproof. Water through the flue does happen...
STUFF: Samsung LE46A756, Denon AVR-2309, TMA 903MK-IV, Canton Movie 150 QX, Logitech Harmony 785.
HTPC: Silverstone LC13-E based HTPC, 2TB mirrored media server.
WIP: Building my own floating wall...
M.D. Klapwijk is offline   Reply With Quote
ninja tattoo (19-06-2009)
Old 19-06-2009, 9:27 PM   #6 (permalink)
Re: fireplace
Does it?
Cheers mate, didnt realise that, although it would be all sealed but I'll make sure theres no danger from any moisture down the flue
Old 20-06-2009, 9:01 AM   #7 (permalink)
Thanks: Gave 0, Got 3
Re: fireplace
Does anyone know what the construction in front of the flue is? I too have removed my fireplace and now have a projector mounted above. I want to drill through and run the cables down the flue, is this possible?
Woody26 is offline   Reply With Quote
Old 20-06-2009, 9:35 PM   #8 (permalink)
Re: fireplace
Yeah Im the same, Ive heard the flue is quite small but I also want to drill through the brickwork n drop the cables down.
Failing that IF the brick work is solid then it might be worth channelling the cables 'into' the brick work n then plastering over it.
Old 21-06-2009, 9:53 AM   #9 (permalink)
Re: fireplace
I don't really want to do that, but last resorts will have to be!
fireplace
