3.5 million visitors each month
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Star Wars: The Clone Wars Blu-ray ReviewPublic Enemies - Original Motion Picture Soundtrack CD ReviewAudition Blu-ray ReviewPolice Story Blu-ray ReviewYear One Blu-ray Review
The Living Dead At Manchester Morgue Blu-ray ReviewPublic Enemies Blu-ray ReviewGojira Blu-ray ReviewHalloween II Original Motion Picture Score - Expanded 30th Anniversary Edition CD ReviewStar Trek - Complete Original TV Show Season 2 Blu-ray Review
K800i - How to fix and what part required? Liam_123 Sony Ericsson Mobile Phone Discussions 3 27-07-2009 1:57 PM
Sagem HD-D50 - "halo" effect, how to fix? HellraiserUK Rear Projection Televisions 6 15-06-2009 7:11 PM
Fix the shotgun? realitygate Gears of War Xbox 360 22 14-06-2009 11:34 AM
Samsung PS42c91hx - Full of problems I'd like to know if they are possible to fix 2good4you Plasma Televisions 2 08-06-2009 11:11 AM
My New Samsung YP-Q1 is Broken Already:( Anyone got any ideas how to fix it?! Aky705 Portable Music (MP3, iPod etc.) 1 07-06-2009 11:34 AM
Old 08-06-2009, 8:18 PM   #1 (permalink)
Grangey.'s Avatar
Thanks: Gave 41, Got 84
Plasterboard/ plaster question. What would cause this? how would i fix it?
Hi all,
hope you're doing well.
Im thinking of updating/ modernising one of our upstairs bedrooms and turning it into a media room. Now the house was converted about 25 years ago from a bungalow and one thing thats always annoyed me is the way the plasterboard has been put up and I want it sorted.
Basically where the virtical wall meets the slope going into the seiling, the line isnt true/ straight.. and this is the case most the way around the room
So i was just wondering what would of caused this? And how easy it would be to rectify? Would it be something that can be sorted by having the room re-skimmed? or even something as simple as some extra plaster?
Im open for suggestions really?
On a side note, the room I believe has simply been painted directly on to plasterboard rather than plastered fully and Id love a nice clean finish. currently some of the joints are cracking abit so I was wondering whether patching plaster would surfice to cover these cracks, and plenty of coats of paint will hide the signs of plasterboard, or whether im better off getting the room plastered properly (the room is approx 18ft x 25ft so any suggestions how much this may cost would also be appreciated)?
Thanks in advance,
Grangey
Sony KDL40W2000, Onkyo TXSR875B, SONY PS3, Xbox 360, Sky HD, Wii, B&W 603's, AE 107C, and some cheaper speakers to compleate the 7.1 Speaker setup.
Grangey. is offline   Reply With Quote
Old 08-06-2009, 9:04 PM   #2 (permalink)
Thanks: Gave 10, Got 4
Re: Plasterboard/ plater question. What would cause this? how would i fix it?
I've got a similar problem in our cellar
...put it down to the beams not being level when it was boarded out...even though we've rebuilt things down there, pulling the ceiling down and levelling it off is one thing I can live without...yes it bugs me but figured I won't be able to see in the dark and will have stuff in front of me to take my mind off it.
I'm painting the walls dark brown and leaving the ceiling white (initially at least...).
Was thinking of pulling the ceiling colour down the wall a couple of inches to a straight line around the room which will mask the dips rather than have the contrast of two tones meeting on the wobbly edge (if that makes sense!) - this may visually lower the height of our room and not work for us. Yours is higher though so you may get away with such a cheap trick...and white paint is cheap enough to give it a go...
Failing that, paint the ceiling the same colour as the walls and it won't be as noticable
KDL46X3500, KDL32V5500, HD65, Panoview 84", Harmony 1000, STRDA3200, PASCAL 7.1, PS1, PS2, PS3, XBox, Xbox 360, NES, Super NES, N64, Gamecube, Wii, Master System, Mega Drive, Saturn, Dreamcast, 3DO, Jaguar, Atari 2600.
norty mart is offline   Reply With Quote
Old 08-06-2009, 9:12 PM   #3 (permalink)
Grangey.'s Avatar
hmm that makes sense, thanks for the input. shame theres not another way around it really as re-plasterboarding the whole room would be rraather costley, although I would enjoy it lol.
Just out of interest, what are you doing/ have you done with that wall? if so did you get it plastered? did you do it yourself or pay for someone? how much did it cost?
Grangey
Old 08-06-2009, 9:25 PM   #4 (permalink)
Thanks: Gave 6, Got 8
How about draw a thick line a little way down the wall with a spirit level and have a plaster skim so that some of the line is still showing. The ceiling should be virtually level then.
Samsung LE40A557 - Sky+ HD - Xbox 360 Elite - PS3 80gb - Nintendo Wii - Eltax Jupiter Fronts, center and rears
MattBennett is offline   Reply With Quote
Old 08-06-2009, 9:38 PM   #5 (permalink)
I've got a thread running showing our wip...
cellar rebuild
All done by my own fair (now dry and rough...) hands.
The 'wall' was a chimney breast with an alcove each side but I had to hide a waste pipe from the pump and wanted to do something different.
Cost-wise, in your case you can drop the price of the membrane/pump from what we've spent so just a £100 on timber (stud & flooring), about £70 on plasterboard and £60 (give or take) on screws/plumbing fittings etc. - room is around 3mx4m and just under 7ft high.
edit: plus around £100 on MDF for the storage carcasses.
Plan out what you're making and draw up some cutting plans for the man at B&Q...he'll give you a hard time but it saves you time, waste & money
We plan on having it skimmed but are yet to entice somebody in to quote on the job so can't give you a price yet (pic was taken last night) - at a guess each niche will be treated as a window and bump the price up to cover edge strips etc. so won't represent what it'd cost to skim a plain room of the same size.
fix, plasterboard or, plater, question
