Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
My Bloody Valentine - Special Edition Blu-ray ReviewThe Universe: Complete Season One Blu-ray ReviewTerminator Salvation Blu-ray Review20th Century Boys: Chapter 2 - The Last Hope Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray Review
Scrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
HKTS7 Speaker Set eBay JanBosman Speakers 37 14-07-2009 9:15 PM
EPOS ELS settings? creative Subwoofers and Tactile Transducers 24 16-06-2009 4:03 PM
So why aren't these smaller "HD Ready" sets 16:9?? Restorer LCD Televisions 24 07-06-2009 7:02 AM
Jamo A102HCS5 or Harman Kardon HKTS7 Speaker Set oliphillips Speakers 0 06-06-2009 9:00 PM
Old 06-06-2009, 10:30 PM   #1 (permalink)
oliphillips's Avatar
Thanks: Gave 12, Got 20
Trunking for Wall Mounted Set Up
I will be looking to install trunking for mounted TV. I have found some cheap trunking originally meant for air conditioning cabling. I am going to want to run 3 X HDMI cables, 3 X Phono cables, Power Lead through it. Can't think of anything else am i missing something obvious!?? What size do you reckon I should order:
70x55mm, 90x65mm, 125x75mm
Plan is to then paint over it with the same colour as the walls. Also anyone got any links to cheaper of better stuff? Also need 2 very thin pieces of trunking for use with 2 mounted rear speakers, literally just a speaker cable going in there so need something really thin.. Can't do too much as i'm renting and the landlord would probably go mad!
Will appreciate any tips/advice of using trunking to hide cables from mounted tv.
Cheers, Oli
EDIT: just need info for the trunking for the tv mount
oliphillips is offline   Reply With Quote
Old 07-06-2009, 10:24 PM   #2 (permalink)
Thanks: Gave 5, Got 1
Re: Trunking for Wall Mounted Set Up
Cheers, Oli
Hey oli,
Have you had a look at the d-line trunking, it is good value, and it is self adhesive, and easy and simple to put up and remove. They do various sizes and colours, and you can also paint them.
Regards Tom
Kit list : Samsung LE40A616A, sony bdp-s350, xbox 360 elite, sky +, onkyo 606, fisual qed and van damme cables, hp mediasmart server, custom built pc, samsung sm2333sw. wharfedale 9.1 stereo speakers. Soon to have some kef eggs for surround duties
Tom_Associated is offline   Reply With Quote
oliphillips (07-06-2009)
mounted, set, trunking, wall
