3.5 million visitors each month
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Star Wars: The Clone Wars Blu-ray ReviewPublic Enemies - Original Motion Picture Soundtrack CD ReviewAudition Blu-ray ReviewPolice Story Blu-ray ReviewYear One Blu-ray Review
The Living Dead At Manchester Morgue Blu-ray ReviewPublic Enemies Blu-ray ReviewGojira Blu-ray ReviewHalloween II Original Motion Picture Score - Expanded 30th Anniversary Edition CD ReviewStar Trek - Complete Original TV Show Season 2 Blu-ray Review
Advie needed : Archos 160 gb or Ipod Classic 160 GB nikunj_cal Portable DVD and Media Players and Recorders 3 29-10-2007 8:13 PM
Advie on HDMI to DVI please pjking PS3 14 16-04-2007 1:09 PM
Old 04-06-2009, 9:53 PM   #1 (permalink)
Thanks: Gave 4, Got 16
wanting some advie
looking to build a flase chimmley breast but wanting some tips and advice on doing this
thnx in advance
scodav is offline   Reply With Quote
Old 05-06-2009, 12:14 PM   #2 (permalink)
Showoff's Avatar
Thanks: Gave 43, Got 60
Re: wanting some advie
thnx in advance
Your question is a bit vague mate.
What specifically do you want to know or I may as well post, get some wood, nails, screws, plasterboard, plaster, paint, stick it all together and Voila!
PJ: Infocus IN80 | Screen: Optoma Panoview 92" DE9092EGA | TV: LG 42PC1D with SkyHD & Cable | Amp: Pioneer SC-LX81 | Speakers: Front MA GR60's, Centre MA GSLCR, Rear MA GSFX's | Sub: BK Monolith DF | Remote: Harmony 1100 | Gaming: PS3 & Wii | Headphones: Sennheiser 595. Showoff's Home Cinema
Showoff is offline   Reply With Quote
Old 05-06-2009, 12:49 PM   #3 (permalink)
sorry bout the first post been bad i want some advice on wht materials are the best to use and some tips on making the framework and how to get the best finsh hope that is better
thnx again
Old 06-06-2009, 8:41 AM   #4 (permalink)
Thanks: Gave 5, Got 2
Hi scodav,
I'm currently building a fake chimney myself, you can see my progress here - ....and so it begins - my first install, a fake chimney breast
I've built the frame using CLS timber from B&Q (CLS Timber (L)2400 x (W)63 x (T)38mm, 5014957047211), it's not the best for quality and if you spend a few mins when buying it to weed out the obviously warped lengths you should be fine. I've used the 6x100mm TurboGold screws from Screwfix (TurboGold® Countersunk Screws 6 x 100mm Pack of 100 - Screwfix.com, Where the Trade Buys). They have easily pulled the frame together where they were a few pieces still out of line and they reckon you can get away without having to drill pilot holes (although I've still drilled holes in most cases, just in case of splitting the timber)
I've planned on making the faces from mdf but now I've got to that part the front face is looking fairly daunting so that may change in the next few hours!!
Hope this helps, I'm new to this myself so I'm sure some of the more experienced members may have a few different ideas!
Cheers,
James
p.s. Sorry about the long links, I couldn't figure out how to give them a short title!
jamesk190 is offline   Reply With Quote
Old 06-06-2009, 8:42 AM   #5 (permalink)
p.p.s......just realised that the forum does all sorts of clever things in the background and just displays the page title anyway so ignore that last comment!!
advie, wanting
