Free electronics advice and information
3.5 million visitors each month
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Cinema DIY
Latest AVForums Movie Reviews
Clash Of The Titans - Original Motion Picture Soundtrack CD ReviewZombieland Blu-ray ReviewLast King of Scotland, The Blu-ray ReviewAfrican Queen, The Blu-ray ReviewCirque du Freak: The Vampire's Assistant Blu-ray Review
Toy Story Blu-ray ReviewClash Of The Titans Blu-ray ReviewVengeance Blu-ray ReviewHellboy Animated: Sword Of Storms/Blood and Iron Blu-ray ReviewThe Andromeda Strain - Motion Picture Soundtrack CD Review
Thread Thread Starter Forum Replies Last Post
My HTPC build Kuminauha Home Entertainment PCs 2 04-06-2009 9:10 PM
Mounting 50" Plasma to Hollow Concrete Wall? benmc Flat Screen TV Brackets and Mounts 5 04-06-2009 8:42 AM
Advice needed for concealing speaker wires/cable in plastered wall bigbug Home Cinema DIY 4 03-06-2009 7:51 PM
Help with fixings for 46" wall mount Dodgy Bob Flat Screen TV Brackets and Mounts 2 03-06-2009 6:54 PM
Old 04-06-2009, 9:21 AM   #1 (permalink)
M.D. Klapwijk's Avatar
Thanks: Gave 7, Got 18
Building my own floating wall
Hi all, first let me introduce myself. My name is Marcel and I'm about to start building a floating wall in my living room. I've been greatly inspired by Groove's work and will be using some of his idea's. (Well rip most of them... )
So to kick this project off, here's is the first art impression I made with Photoshop:
Dimensions I'm going to work with:
- Wall: 4200 x 3650 mm
- Floating wall: 3600 x 2100 mm
- Frame: 3440 x 2020 mm
- Clearance: 77 mm
- Overhang: 80 mm
Components:
- Samsung LE46A756 LCD
- Audipack Flatfix mount (clearance 28 mm)
- Denon 2309 amplifier
- TMA 903MK-IV stereo speakers
- Canton Movie 150 QX 5.1 to complete 7.1 setup
- DIY Media computer
- Ikea Besta cabinets (2x1200x380x400 mm and 2x600x380x400 mm)
M.D. Klapwijk is offline   Reply With Quote
Old 04-06-2009, 9:48 AM   #2 (permalink)
Re: Building my own floating wall
Oops, made a little mistake resizing the image (resized without resizing the layer effects)...
Old 04-06-2009, 9:50 AM   #3 (permalink)
hockfoci's Avatar
Thanks: Gave 1, Got 0
Looking cool, keep the update pics coming
Started ours this week..........groove....you should have ©'d the idea lol
hockfoci is offline   Reply With Quote
Old 04-06-2009, 10:00 AM   #4 (permalink)
Will be posting progres pictures, only need to buy a cf-reader since I lost the cable of my camera. Now I'm back to clearing the livingroom...
One should really call it a Groove Wall...
Old 04-06-2009, 10:32 AM   #5 (permalink)
hockfoci's Avatar
I agree, anyone asks ....I'm building a Groove wall
Old 04-06-2009, 7:00 PM   #6 (permalink)
Ok outer frame is standin... ehhh floating I meant. Tomorrow I'll be buying a card-reader and will post the first day pictures.
Old 05-06-2009, 12:41 PM   #7 (permalink)
Ok, here are the progression shots of day 1:
The tv, stereo, speakers...
... and cabinets...
... which all will have to make room.
Testing the dimensions in real life.
The first barn raising. I joined the frame with some corner irons, so I could lift it by my self. I then leveled the frame and marked the wall for mounting points.
Now it's level and fixated with 2 of 6 m6 bolts.
Time to place the first...
... and second outer leg.
Unmounted the upper part of the frame to drill the 4 other holes, mark them on the wall...
... and fixate the upper part again.
About to test the tube lightning.
DAMNED!
Repaired the 2 light zones, which were broken.
Testing the 8cm overhang. I think it's ok...
Building my own floating wall-dscf0399.jpg   Building my own floating wall-dscf0404.jpg   Building my own floating wall-dscf0407.jpg   Building my own floating wall-dscf0408.jpg   Building my own floating wall-dscf0410.jpg
Building my own floating wall-dscf0412.jpg   Building my own floating wall-dscf0414.jpg   Building my own floating wall-dscf0415.jpg   Building my own floating wall-dscf0416.jpg   Building my own floating wall-dscf0417.jpg
Building my own floating wall-dscf0418.jpg   Building my own floating wall-dscf0419.jpg   Building my own floating wall-dscf0421.jpg   Building my own floating wall-dscf0422.jpg
Old 05-06-2009, 8:35 PM   #8 (permalink)
And here's todays result:
Placing more of the frame...
... and an other one...
... and again...
... and again...
... and finally the tv mount.
And here we go again, more frame...
Test fitting the Samsung. Once again I think it's ok.
Tomorrow I'll be painting the outerframe in a satin white for some more diffuse reflection and putting the wires in place...
Building my own floating wall-dscf0427.jpg   Building my own floating wall-dscf0428.jpg   Building my own floating wall-dscf0429.jpg   Building my own floating wall-dscf0430.jpg   Building my own floating wall-dscf0431.jpg
Building my own floating wall-dscf0432.jpg   Building my own floating wall-dscf0433.jpg   Building my own floating wall-dscf0434.jpg   Building my own floating wall-dscf0435.jpg
Old 06-06-2009, 10:05 AM   #9 (permalink)
I think about placing horizontal beams at the bottom of the crosses aswell. Or would the 18 mm MDF be ridgid enough?
Old 06-06-2009, 2:42 PM   #10 (permalink)
Thanks: Gave 0, Got 18
I would put some horizontal beams across in my opinion.
Also, you sure about the 80mm overhang? I've built a floating wall (albeit not for a tv) and have a 50mm overhang which seems to give a nice light around it, any wider I think the light wouldnt cast far enough out to give a nice glow. Just a thought anyways. Looking good though
Sorry for crappy picture but this is with a 50mm overhang. (excuse the non-matching bed sheets!)
SparksCW is offline   Reply With Quote
Old 06-06-2009, 3:38 PM   #11 (permalink)
I know 80 mm is a bit more, but the spacing from the wall is 77 mm due to the depth of the HTPC. 80 is about the overhang wich blocks the lights from direct line of sight.
Check out this picture, the glow seems ok to me:
Will be creating some extra beams tomorrow though...
Old 06-06-2009, 7:58 PM   #12 (permalink)
Well that was a day well spent, watching the paint dry. Done some work in the toilet and bathroom though...
Tomorrow 08:00 painting the backside of the MDF boards and then the wires.
Old 10-06-2009, 9:49 AM   #13 (permalink)
Quick update:
Extra beams and the backside painted.
Right and...
left panel made and test fitted.
Testing the ligtning, again.
Building my own floating wall-dscf0436.jpg   Building my own floating wall-dscf0439.jpg   Building my own floating wall-dscf0440.jpg   Building my own floating wall-dscf0443.jpg
Old 10-06-2009, 2:37 PM   #14 (permalink)
Just finished the center plate:
Now I finally can screw the plates to the frame, ehhh, no need to vacuum first...
Old 10-06-2009, 8:08 PM   #15 (permalink)
Last update for today:
Finally fixed the center board to the frame.
Testing lights and tv again and fitted the wires.
Cabinets check!
The lights seem a bit hard in the picture, but in real they're more yellow.
Later this week I'll be fixing the left and right board to the frame. So what do you all think so far?
Building my own floating wall-dscf0448.jpg   Building my own floating wall-dscf0449.jpg   Building my own floating wall-dscf0452.jpg   Building my own floating wall-dscf0453.jpg
building, floating, groove, wall
Copyright © 2000-2010 M2N E. & O. E.
