bose
Old 25-07-2012, 10:12 PM   #1
Thanks: Gave 4, Got 2
bose
hello all, just got myself a new samsung 8000 tv, i have had a bose surround sound speaker system for about 12 years, 5 cubes and a sub, i used a yam didgital amp to power them, i have not used them for a few years but now i have a decent tv was thinking of surround sound again. would i be better buying newer speakers as time and tec have moved on or are they still good?
Old 26-07-2012, 12:06 AM   #2
Illustrious Member
davepuma's Avatar
Thanks: Gave 570, Got 2,613
Speaker technology doesn't change that much whereas AV Receivers are updated annually. They don't change that much and large updates are introduced every 3 or 4 years when the 'next big' thing arrives. At present most, if not all AV Receivers can handle HD Audio (DTS HD Master Audio, Dolby True HD) via HDMI, passthrough 3D (HDMI v1.4) etc. This year's models tend to be adding things like networking, airplay, 4K upscaling.
I would definitely recommend you visit a dealer and arrange a demo of some new equipment. Obviously how big a difference new equipment and new speakers will make will depend on how deep your pockets are and how good your hearing is!
Old 26-07-2012, 12:32 PM   #3
thanks for the reply i shall take your advise, the amp is quite a few years old now so i reackon that will be my first change,, thank you.
Old 30-07-2012, 8:43 AM   #4
Thanks: Gave 0, Got 4
Bose 5.1
what model of Bose do you have is it an all one system?
