Do try to set up the speakers symmetrically round the TV e.g. left and right speakers to the left and right of the TV. I know it may sound silly, but if people insist on keeping the TV in the room corner (where the old CRT TV used to be) then they can have real problems setting up the speakers properly. -- Already done
Do spend time (a lot!) on setting up the TV. A good start is to switch off all the special picture features (and only gradually bring them back in -
if it improves the picture), and reduce the colour temperature to about 6500 K (most sets are much too high). -- Done
Don't have the sub-woofer turned high. -- Done
Run the player through the amplifier via HDMI cables; so you get high resolution audio as well as pictures. -- Already Done
Set the TV so it "just scans" all HD inputs; and make sure the player is outputting at 24fps. -- This is where I need more input. i.e, How to set the TV so it "Just Scans" all HD inputs. Again struggling with the 24 fps part.
This was for the player, whats the best tips for getting best out of the HD box.
