How can blu-ray player work in 5.1 surround sound using home cinema system
Old 14-11-2009, 4:55 PM   #1
1,363, Level: 8
Points: 1,363, Level: 8 Points: 1,363, Level: 8 Points: 1,363, Level: 8
Need help!
Just bought LG dvd home cinema system. My problem is that I cannot get the 5.1 surround sound working through my blu-ray player. It works fine with the dvd home cinema provided.
I tried different things including:
(1) having an optical lead from the tv to home cinema system and hdmi cable from tv to blu-ray player and only certain speakers will work (but not 5.1).
(2) having the optical lead from home cinema system to blu-ray player and hdmi cable to blu-ray player and still only some speakers work.
It is the rear speakers that have no output sound.
Is there something im missing from my setup up? Is there a way of getting my blu-ray player to work in 5.1 through my home cinema system?
Old 15-11-2009, 10:16 AM   #2
davepuma's Avatar
32,020, Level: 43
Points: 32,020, Level: 43 Points: 32,020, Level: 43 Points: 32,020, Level: 43
Activity: 29.7%
Activity: 29.7% Activity: 29.7% Activity: 29.7%
Thanks: Gave 396, Got 2,177
Re: How can blu-ray player work in 5.1 surround sound using home cinema system
Connect the Bluray player direct using the optical cable and set to bitstream in the audio setup.
Old 15-11-2009, 3:27 PM   #3
1,363, Level: 8
I've connected optical cable to the blu ray player but have had no luck within the set up of my blu ray player. I have no option to set to bitstream in the audio setup?
Old 15-11-2009, 4:32 PM   #4
davepuma's Avatar
32,020, Level: 43
Activity: 29.7%
What player is it? What audio settings are available? Do yoy have a link to the online manual?
Old 15-11-2009, 4:54 PM   #5
1,363, Level: 8
Once you mentioned online user manual I checked that out and now i know the bitstream was 2ch PCM. So set Audio output to that and the audio output priority (as my bluray player audio setup states) to coaxial/optical and now I've got 5.1!!
Thanks for the help.
