Hi ketfc,
Thanks for this update, really useful to see how other people are using their Sonos system.
I'm not sure my Sonos is the issue to be totally honest. I've been using it with a Devolo mains line adapter and my WD 1Tb MYBOOK Nas without any issues from day dot, music all around no problem.
The thing that's causing signal problems is the video sender I have transmitting my Sky signal upstairs. Even though Sonosnet is supposed to be independent of the 2.4Ghz video senders broadcast on I have at times had to switch the video sender channels and found that Sonos
did cross the band because I turned my zone players off and the video sender signal cleared up.
However I think someone nearby bought a wireless router and I found a program called NetStumbler which lets you see whats broadcasting wireless-wise around and can see lots of new dots I never saw before. I personally have my wireless turned off as I am cabled using the mains adapters in most places I need access to my LAN.
With the whole 'signal' interference problem, I didn't even fancy upgrading my video sender to a 5.8Ghz one to get away from the routers just to get stuck in the same issue again when someone buys a 5.8GHz DECT phone which I hear are in dev in a year or two. I've never had any major interference problems in the 3 years I had my Sonos, so I went the way of the SingboxPro-HD and SlingCatcher.
Now the interference issue is gone, as the Sky signal is sent over my LAN (also over the mains adapter actually!) and also the catcher allows me to browse network shares and play video files from my NAS on my upstairs telly too.
An expensive solution I agree, but it gives me additional functionality and if someone buys a DECT phone or different router I won't be pulling the little hair I have left out again...!
Cheers for your time tho, much appreciated!!
