bose cinemate 2.1 help
Old 06-11-2009, 11:21 AM   #1
1,571, Level: 9
Points: 1,571, Level: 9 Points: 1,571, Level: 9 Points: 1,571, Level: 9
Thanks: Gave 2, Got 0
Hi i have a bose cinemate 2.1 system and want to connect it to a pioneer 2016 amp 7.1 as the sub and front 2 speakers can i do this? the front 2 speakers connect to the sub and the sub has a cable with red and white audio cables but when i connect this to the pioneer amp the sound only comes out the left speaker. can anyone suggest anything? thanks tom
Old 06-11-2009, 11:28 AM   #2
davepuma's Avatar
32,020, Level: 43
Points: 32,020, Level: 43 Points: 32,020, Level: 43 Points: 32,020, Level: 43
Activity: 29.7%
Activity: 29.7% Activity: 29.7% Activity: 29.7%
Thanks: Gave 396, Got 2,177
Re: bose cinemate 2.1 help
No is the short answer.
pokerdaft (06-11-2009)
Old 06-11-2009, 12:42 PM   #3
5,603, Level: 17
Points: 5,603, Level: 17 Points: 5,603, Level: 17 Points: 5,603, Level: 17
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 70, Got 70
Isn't that an active 2.1? Why do you want to mess with that?
Old 06-11-2009, 10:02 PM   #4
1,571, Level: 9
hi the sound from the bose is brill but i would like to get 5.1 or 7.1 im not to sure what active means as ian new to this thanks could you explain please
Old 06-11-2009, 10:18 PM   #5
5,603, Level: 17
Activity: 1.4%
It has inbuilt amplification so you don't need to connect it to an amplifier.Powered speakers - Wikipedia, the free encyclopedia. You can connect them directly to a TV, PC , dvd player etc. Is the Bose like that ? I don't know the technical details but I think these type of systems are designed to work only on their own.
