Help!!!
Old 05-11-2009, 2:39 PM   #1
1,340, Level: 8
Points: 1,340, Level: 8 Points: 1,340, Level: 8 Points: 1,340, Level: 8
Help!!!
I have a Toshiba Regza 32AV615DB TV Humax 9300T PVR Yamaha YSP600 Sound Bar Xbox 360 Elite (use as dvd player and games console) and an Aspire L3600 PC running on windows 7
I have the TV (HDMI 1) connected to the Sound Bar (HDMI out) and the humax connected to the sound bar (dvd in) and the xbox 360 connected to the sound bar (aux in)
I have my pc connected to the tv with a DVI cable to the HDMI 3 on the TV (HDMI 2 doesnt recognise PC)
I would love to be able to use the sound bar with my PC as well to get the added benefits of vitual surround sound as opposed to my 2.1 speaker system on the PC.
Is this possible and have I set up all the components correctly
Any Help would be appreciated
Old 05-11-2009, 2:51 PM   #2
davepuma's Avatar
32,020, Level: 43
Points: 32,020, Level: 43 Points: 32,020, Level: 43 Points: 32,020, Level: 43
Activity: 29.7%
Activity: 29.7% Activity: 29.7% Activity: 29.7%
Thanks: Gave 396, Got 2,177
Re: Help!!!
You will need to connect up an audio cable from the PC to the soundbar. A quick google reveals that it has digi-coax audio output (spdif) so you will need a digi-coax cable (progiold at £12 is good enough). It also has 7.1 analogue audio output, which would be using 3.5mm to phono cables. I don't think the soundbar has multi-channel analogue audio inputs though, so spdif would be the way to go.
