help needed
Old 01-11-2009, 9:17 PM   #1
1,359, Level: 8
Points: 1,359, Level: 8 Points: 1,359, Level: 8 Points: 1,359, Level: 8
help needed
hi
i am new here i have serched and cant find answer to my problem.
i have a panasonic txp42g10 plazma. i bought a home cinema system panasonic scpt460. conected to tv via hdmi cable and cable box via phono leads into the system everthing works fine untill i turn my tv into tv mode when watching normal channels the sound goes through tv speekers how can i hear this through cima system.
i mainly watch bbc HD via freesat i would like to hear the sound through cinma system any help apriciated
many thanks
Old 01-11-2009, 9:29 PM   #2
davepuma's Avatar
32,020, Level: 43
Points: 32,020, Level: 43 Points: 32,020, Level: 43 Points: 32,020, Level: 43
Activity: 29.7%
Activity: 29.7% Activity: 29.7% Activity: 29.7%
Thanks: Gave 396, Got 2,177
Re: help needed
You will need to connect an audio cable from the TV to the home cinema system which will be analogue phono (red/white) or optical. If you want 5.1 from BBC HD, then optical is the way to go, if your home cinema system has an optical input.
Old 01-11-2009, 9:35 PM   #3
1,359, Level: 8
Re: help needed
thanks for the reply i conected the phono leads from tv into the cinma system but it dident work. is there and other way round this
Old 01-11-2009, 9:43 PM   #4
davepuma's Avatar
32,020, Level: 43
Activity: 29.7%
Re: help needed
Make sure the audio connections on the TV are outputs, not inputs. They should be marked with an arrow pointing outwards.
