Home Cinema 'DIY SOS' - Floating Wall
Old 15-05-2009, 2:17 PM   #1
Godspeed's Avatar
4,748, Level: 16
Points: 4,748, Level: 16 Points: 4,748, Level: 16 Points: 4,748, Level: 16
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 133, Got 191
Anyone see last nights 'DIY SOS' episode?
They've even jumped on the bandwagon of floating walls from snellfish's original idea!
I've got some pics I can upload, although not great as they are camera phone pics from a paused source.
They also used textured MDF sheets to create a 'textured wall' which looked fantastic - sort of ripples in the sand effect
G
Old 15-05-2009, 4:27 PM   #2
4,444, Level: 15
Points: 4,444, Level: 15 Points: 4,444, Level: 15 Points: 4,444, Level: 15
Thanks: Gave 1, Got 71
Re: Home Cinema 'DIY SOS' - Floating Wall
It's available on the BBC iPlayer - DIY SOS: Series 18: Elping out in Essex, (floating wall idea ~13.20).
Old 15-05-2009, 5:13 PM   #3
Godspeed's Avatar
4,748, Level: 16
Activity: 3.4%
Pics added
Old 15-05-2009, 5:24 PM   #4
14,423, Level: 28
Points: 14,423, Level: 28 Points: 14,423, Level: 28 Points: 14,423, Level: 28
Activity: 3.8%
Activity: 3.8% Activity: 3.8% Activity: 3.8%
Thanks: Gave 1,340, Got 950
I thought it was much better than the 'cinema room' on Grand Designs the other week....an all white room with big windows. They always seem to do a good job on DIY SOS, with all the plastering, wiring, etc, unlike the 1/2 day makeover rubbish that was 'Changing rooms'. I'd have loved for DIY SOS to come and do my house (not that I deserve it, just it would have been nice ) as it's taken me 8 years to get it straight, but at least I did it and I only trashed one room at a time.
Old 15-05-2009, 5:32 PM   #5
7,290, Level: 20
Points: 7,290, Level: 20 Points: 7,290, Level: 20 Points: 7,290, Level: 20
Thanks: Gave 46, Got 78
Anyone got a UK source and price for the textured MDF?
Old 15-05-2009, 5:47 PM   #6
Godspeed's Avatar
4,748, Level: 16
Activity: 3.4%
Of course you could always take the dvd shelves off the side of this and then bolt it to the wall for the grand sum of £43........
Last edited by Godspeed; 15-05-2009 at 10:16 PM. Reason: image now doesn't breaks forum rule no.9
Old 15-05-2009, 7:50 PM   #7
KUBBY's Avatar
11,185, Level: 25
Points: 11,185, Level: 25 Points: 11,185, Level: 25 Points: 11,185, Level: 25
Activity: 13.5%
Activity: 13.5% Activity: 13.5% Activity: 13.5%
Thanks: Gave 127, Got 570
Just watched this.
Could have done with less "Apple Bobbing" and more on the construction side.
Is it just me,or are they spending less screen time on the actual work and more on the messing around sillyness?
Nice result though.
KH
Old 16-05-2009, 11:25 AM   #8
14,423, Level: 28
Activity: 3.8%
Nice result though.
KH
I agree, but TBH there's only so many shots of them mixing plaster and applying it that I can take.....it's enough to know that they are doing this (and therefore a 'proper' job). IMHO they also spoiled the 'reveal' by showing bits of the finshed room at the start of the show; where they were explaining what they were going to do. Have we really become such an impatient audience that we can't wait to the end to see what it looks like?
Old 17-05-2009, 4:12 PM   #9
2,731, Level: 12
Points: 2,731, Level: 12 Points: 2,731, Level: 12 Points: 2,731, Level: 12
Thanks: Gave 3, Got 5
Just watched this.
Nice result though.
KH
I usually watch it for Nick Knowles as he makes me laugh! It is more of a light hearted DIY program then most though
Old 18-05-2009, 12:16 PM   #10
3,718, Level: 14
Points: 3,718, Level: 14 Points: 3,718, Level: 14 Points: 3,718, Level: 14
Thanks: Gave 21, Got 55
I'm sure i have a link to a supplier of those MDF sheets at home somewhere, they are manufactured by a Chinese company iirc. One of my local restaurants has them as panels on the wall to help acoustics. Or the swedish alternative can be found here.
Old 18-05-2009, 12:39 PM   #11
2,134, Level: 10
Points: 2,134, Level: 10 Points: 2,134, Level: 10 Points: 2,134, Level: 10
Thanks: Gave 1, Got 12
According to the DIY SOS forum the textured MDF is Reed-300 from Fourth Dimension. Looks like it's around £170 for a 2500mm x 1250mm panel. n Dimensions standard range of 3D patterned surfaces produced from routing
The wallpaper is Cow Parsley 70/6013 by Cole and Sons.
Lemon_Sherbert (18-05-2009)
Old 18-05-2009, 2:16 PM   #12
1,738, Level: 9
Points: 1,738, Level: 9 Points: 1,738, Level: 9 Points: 1,738, Level: 9
Thanks: Gave 27, Got 32
Nice find cw2k,
They do A4 samples for only £15 as well, might have a look at that, they were a bit funky!
From the site.....
"Samples – A4 (nominal) unlacquered samples of each design can be ordered at a cost of £15.00 ea., inclusive of packing, delivery and VAT"
Old 17-12-2009, 9:48 AM   #13
Linx08's Avatar
3,568, Level: 14
Points: 3,568, Level: 14 Points: 3,568, Level: 14 Points: 3,568, Level: 14
Thanks: Gave 0, Got 135
textured panels
I also sat up and thought wow that textured wall is cool, there's loads of choices out there for walls. a company called mobilia do something similar (www.mobilia.ltd.uk) in fact they do loads of different styles haven't got any prices yet.
Also there are other companies that do something similar but instead of good old MDF they make it from plaster, they do one that does look like wind blown sand as well as something similar to the one that was on the show which they call bamboo. Very cool I've been earching for something to use as a fature wall in my gaff, but at £170 a sheet that makes my feature wall cost something like £850. GULP!!!!
