Need advice to decorate empty wall!
Old 26-10-2003, 10:21 PM   #1
Loafer316's Avatar
4,080, Level: 15
Points: 4,080, Level: 15 Points: 4,080, Level: 15 Points: 4,080, Level: 15
Talking Need advice to decorate empty wall!
Hey guys....finally making some progress in decorating the lounge. Basically it's a through lounge. Anyway the second half of the lounge will have a Plasma screen on the wall and AV equipment for 5.1
However i'm flumaxed in what to do with the other blank wall in the front half...was thinking of putting a contempory fireplace there but can only have an electric one which means cheesy artifical flames! Any idea what i could do with with the blank wall? Mozaic? Shelves? i would have spent about 900 on a new fireplace and modern surround...so could probably spend that much on something with a contempory look. Want to avoid side cabinets and pictures/paintings. Stupid i know but i just want something different.
Just need ideas really!
thanxs
Old 27-10-2003, 12:01 PM   #2
WBC WBC is offline
8,304, Level: 21
Points: 8,304, Level: 21 Points: 8,304, Level: 21 Points: 8,304, Level: 21
Thanks: Gave 9, Got 2
Without knowing the room layout and how it is decorated, it might be hard to suggest something suitable.
I know you have mentioned you do not want pictures/paintings but one large contemporary canvas would look cool, if you have the space. Alternatively you could try a large rug of sorts.
Hope this Helps
Stace
Old 27-10-2003, 12:17 PM   #3
jmack
Posts: n/a
http://www.sawitfirst.co.uk/
http://www.interiorinternet.com/
might give you some ideas
a mate of mine has a large spare wall and he has used leather/ suede/ padded squares about 1inch thick about 1 1/2 ft size squares in different colours . different shades of one colour. he has 2 rows of 6
looks really good and he can swop them about when he gets board of 1 arrangment.
he done this because he did not want a canvas or picture wanted more texture and stuff.
they are about 3/4 the way the wall and he has a funky sofa/set thing under it
let us know what you do
Old 27-10-2003, 5:31 PM   #4
Loafer316's Avatar
4,080, Level: 15
Wow thnks guys!!
Basically its a longish lounge measuring 30ft length 15ft width. The room is made up two previous room which had a through lounge.
here is a lame diagram i made from paint!
Old 27-10-2003, 5:39 PM   #5
Loafer316's Avatar
4,080, Level: 15
Blimey!
4 grand for a glass cofee table!
great for ideas though!
