55" Samsung on Floating Wall - From Start To Finish
Old 15-05-2009, 10:13 AM   #1
ShibbyNet's Avatar
1,851, Level: 10
Points: 1,851, Level: 10 Points: 1,851, Level: 10 Points: 1,851, Level: 10
Lightbulb 55" Samsung on Floating Wall - From Start To Finish
Hey everyone, I actually came across AVForums in the first place because I have been looking for examples of "Floating Walls" and low and behold my search landed me on the first and last place to look - AVF!
I have recently bought a 55" Samsung Series 6 HD LCD TV. It is my pride and joy and currently stands on a 3 tier black glass TV stand (Pictures to follow soon). However! No matter how hard I try, with all the AV equipment connected to the TV, hosted within the glass stand there are so many wires, there is just no hiding them...
So I am on a quest for seamlessness! No wires - no mess - no stress!
After thinking of ways around this conundrum I thought my best bet was to look into the floating wall option and 1 week and many hours contemplating later here I am documenting it every step of the way for you.
I am doing this because of my love for all things AV and mostly because the posts that other members have put on here have been so informative and helpful I thought it would be a good idea to give something back t othe community!
Regarding the images, the room is sort of in 2 parts as you will probably be able to make out from the ongoing photos - so - due to the shape of the room it has been difficult to capture any shots at anything other than unflattering angles! so bare with me if the images look like they are from an odd perspective from time to time.
So, here goes
This will be the wall for the floating wall...
So that is a an overview of the shape of the room, whether you can tell or not but the room is essentially in 2 parts, divided by the "archway" the first part with the Computer set up is dedicated to the use of the computer and playing/recording guitar and music in general - the arch then separates and steps down into the AV section of the room - featuring the 55" Samsung and sofa, coffee table etc.
Any questions along the way i will be happy to - well - try my best to answer!
Lets see what we can do with this wall...
Old 15-05-2009, 10:31 AM   #2
ShibbyNet's Avatar
1,851, Level: 10
Re: 55" Samsung on Floating Wall - From Start To Finish
So the wall which the TV is to be mounted on and the floating wall be built against is 113 inches wide.
With the 55" TV in the middle that leave 29 inches for a floating wall BUT of course the wall needs to be smaller than the existing wall and have thus decided to make this 94.4 inches wide, exactly the same width as the cabinets to go below (will post images of these soon) giving 9.3 inches of width space between the floating wall and the existing side wall's - just enough to give a nice glow from the rope light i hope you will agree!?
Old 15-05-2009, 11:37 AM   #3
Sandman's Avatar
9,959, Level: 23
Points: 9,959, Level: 23 Points: 9,959, Level: 23 Points: 9,959, Level: 23
Activity: 2.4%
Activity: 2.4% Activity: 2.4% Activity: 2.4%
Thanks: Gave 119, Got 172
Hi and welcome to the forums, I am looking forward to seeing the progress of this project.
Old 15-05-2009, 11:48 AM   #4
ShibbyNet's Avatar
1,851, Level: 10
Thanks Sandman! I am looking forward to the progress too Hopefully have some pictures up over the weekend of the unit i plan on using for the bottom of the wall - construction won't start until after the weekend however as we have guests coming over and dust and the lack of a TV would suck! ha ha
Old 19-05-2009, 1:58 PM   #5
ShibbyNet's Avatar
1,851, Level: 10
Ok so I have been busy buying and building cabinets to go under the Tv for housing all the AV gear and wires etc and also purchased one hell of wall bracket for the TV it was pricey, over £250 but is a bracket one can be pround of! I will post pictures soon, We had guests over the weekend so i built the cabinets and located thme temporarily to make the place look tidy, but this also gave me a good idea of how the room will look when it is completed and where things should be located too!
Don't worry, i know everyone here like pictures so i will update this post with them later tonight, both bracket and cabinet construction and location
Old 19-05-2009, 6:53 PM   #6
RugbyAl's Avatar
2,841, Level: 12
Points: 2,841, Level: 12 Points: 2,841, Level: 12 Points: 2,841, Level: 12
Thanks: Gave 132, Got 84
Nice looking pair of rooms you have there, I'm looking forward to seeing how this progresses. At least a 'floating wall' should hide some of those wires...
Keep those pictures coming...
Old 20-05-2009, 7:22 PM   #7
Stoke192's Avatar
3,837, Level: 14
Points: 3,837, Level: 14 Points: 3,837, Level: 14 Points: 3,837, Level: 14
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 32, Got 37
Looking forward to see how this progresses.......i notice there's two 360's under your tv.
I take it you've two kids then and it's one each
Old 20-05-2009, 7:34 PM   #8
Tyler Durden's Avatar
6,311, Level: 18
Points: 6,311, Level: 18 Points: 6,311, Level: 18 Points: 6,311, Level: 18
Thanks: Gave 134, Got 66
Consider recessing your items into the wall like >>>THIS<<< before doing a standard floating wall.
Old 21-05-2009, 3:04 PM   #9
ShibbyNet's Avatar
1,851, Level: 10
Tyler Durden your recessed screen in that awesome wall is.... well .. so awesome ha ha, Yeah man don't get me wrong I would love to do that!
But it's a pretty big undertaking - do you mind if i ask the total cost of this build? Minus the AV equipment of course?
Many thanks
Old 21-05-2009, 3:11 PM   #10
6,588, Level: 19
Points: 6,588, Level: 19 Points: 6,588, Level: 19 Points: 6,588, Level: 19
Thanks: Gave 516, Got 76
I'd ask The_Wizard As it's his LoL. Just reply in that thread and ask
Old 21-05-2009, 3:29 PM   #11
2,506, Level: 11
Points: 2,506, Level: 11 Points: 2,506, Level: 11 Points: 2,506, Level: 11
Thanks: Gave 20, Got 17
Shibby not being a fan of anything apple do cept the iphone, i noticed you have an apple fireplace. Since when did they start making home furnishings?
Can't wait to see your final results I'm on the same quest as you as we speak... maybe I should do a thread too.
Old 21-05-2009, 3:37 PM   #12
ShibbyNet's Avatar
1,851, Level: 10
Further construction images: Mostly the cabinets and the beast of a bracket.
I got and adjustabel one as opposed to a fixed because it makes for easier acces for adding and adjusting new cables and aplliances etc. Plus if all else fails i can always use the bracket as a coffee table look at the size of it!! ...
Making holes for wires!
The Beast
The alien hanging fro mthe wall
And this is where we are so far! and yes i DID Photoshop out the wires hanging from under the TV just to give myself the idea of how it will look etc
there are in fact about 6 wires hanging from the TV down to the cabinets below - but not soon!
Today i ordered t he MDF boards and tonight i will be going to get the wood for the frame.
Old 21-05-2009, 3:40 PM   #13
ShibbyNet's Avatar
1,851, Level: 10
Ha ha you are right! lol I was rushing through all these posts and...no, i dont have an excuse i'm an idiot lol
Old 21-05-2009, 3:44 PM   #14
ShibbyNet's Avatar
1,851, Level: 10
Hey man hows it going, yeah the Apple fireplace, it is linked into my home via ethernet to my apple ambiance detector which tells the fireplace to come on or off and at what temperature depending on what the ambience detector picks up the house air condition/temperature to be etc....No i am joking big time - I actually had an Apple sticker lying around so it was begging to be stuck to something so it got whacked central on the granite! But if Apple did do fire places i'm sure they would be cool! or hot - excuse the reverse pun
Yeha ou should start a thread you get plenty of help and idead I have noticed
Old 21-05-2009, 3:51 PM   #15
ShibbyNet's Avatar
1,851, Level: 10
Originally Posted by Stoke192 View Post
Hey Stoke! No one broke aaaages ago and i couldnt be bothered to wait 5 weeks for the turn around so i bought another! So no, no kids - just me! the biggest kid of all :D
Old 26-05-2009, 2:08 PM   #16
ShibbyNet's Avatar
1,851, Level: 10
I had trouble getting my Mac through surround sound recently especially because I have optical leads for both the PS3 & 360 hooked up to 5.1 i wanted to get rid of the harmon kardons and put the mac through the sourrond sound as well but still use 5.1 for downloaded films etc. Scratching my head I ended up speaking to some guys at AWD-IT.co.uk they told me what i didnt know, that infact the Mac Mini has an optical out in the 3.5mm jack it's just recssed! so I bought a few more optical leads off them as well as a 3 in 1 optical splitter allowing for all of the hardware to run on 5.1 with the flick of a button! If you arent an Apple guy and i realize many of you are not AWD-IT offered me a pretty sweet looking set up dedicated to media centers etc. I am a bit of a Mac head so had already bought the Mini before the TV even! So that wasnt the route i went down but there were some pretty slick set ups there worth a look.
After setting up the Mac i realized i hadn't anywhere near enough space for all my Films so shopped around for an external hard drive to hold thme all.
I ended up with a 2TB Lacie again from AWD-IT - they sorted me out with the best price even though it was quite a wad!
Anyway Ropelight ordered today too, should be coming tomorrow and the MDF arrived earlier for the actaul wall part of the floating wall Good times ahead! As well as many a picture soon too.
